Question about Euro-Pro Steam Penguin Hard Surface Steam Cleaner Vacuum
Heats up but nothing happens when handle is depressed
Posted by caribfan on
Anonymous
    New Friend:
  • 3 Answers
Posted on Aug 01, 2010
Can't lower handle on Hoover wind tunnel vac U6432-900
Anne, Do you mean that when you depress the pedal on the left side of the machine body that you can't get the upper portion to release into a lower mode? Or are you fully depressing the pedal?? As for the switch for the self propelled mode, that's actually just a small button that you move around in the slot of the handle to select which mode you want to use. It's not actually a switch. If you are fully depressing the handle release pedal and it's not releasing, you should take it to the store where you purchased it, if it was a vacuum store. If you bought it at a big box store, then you'll need to take it to some repair shop that does warranty work, if it's within the warranty period of course.
Nov 10, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
I have the Ninja Kitchen System 1100 and the only way I've found to lower the handle on the lid is to simultaneously depress the two white "tabs" at the base of the handle. This is awkward at bes
Make sure you have the arrow on the handle in alignment with the arrow on the lid. Press down securely before closing the handle.
Jan 16, 2013 | Vacuums
Eureka HotShot 350A heats up great but no steam when I press button.
Remove water fill cap. Remove rubber washer under cap. Unscrew three phillips head sscrews, one on end of handle, two under rubber washer. Take handle apart. remove clip holding rubber hose onto steam flange. Unloosen plastic steam flange and remove. Using a large pair of pliers or channel locks gently squeeze valve together. It will only move an eighth to a quarter inch. Dove several times until you can depress the pin by hand. Reassemble.
Jan 18, 2011 | Eureka 350A Handheld Steam Vacuum
Plug in but does not heat up, no light on but
The thing just plain broke...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Mar 14, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell Pro heat 9500 2X
I had this same problem, even went out and bought a second machine, same problem. Here was my problem....I was checking the brushes while the handle thingie was in the upright position. You have to be sure and RELEASE THE HANDLE. Now i have 2 perfectly good Bissells.
Jan 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Steam shark model sc 505 uk
THE FILL CAP ON MY SC505 IS JAMMED. CAN NOT REMOVE THE CAP. WHAT ARE MY OPTIONS.
Aug 14, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro Steam Penguin Hard Surface Steam Cleaner Vacuum Logo
942 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Muntejaya Ginting
Muntejaya Ginting
Roxanne Jones
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
