Can you post a picture or reference the model of faucet you have, also it may be quicker to call Rohl directly as warranty may apply and they may cover cost of repair parts and send them to you at no cost. Rohl 714-557-1933
The Diverters Parts is C7005. Here's the parts breakdown for your Rohl faucet. Contact Rohl and have them send you new diveter for free, the A3608 seriers came with a limited liftime warranty.
Hi, there are filters that need cleaning periodically. Undo the nut where the water comes out from the tap, use an appropriate sized spanner, remove meshed filter, clean under running water and replace. Hope this helps
No the length doesn't matter. When you turn the faucet on, you also fill the hose to the sprayer, and it may expand slightly, causing the sprayer to move a little. Is the drip from the end of the spout at the aearator? or is it around the faucet lever. If it is the lever, you should be able to tighten it slightly. If it's the end, make sure your aearator is clean.
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
This faucet is notorious for this problem it is a design flaw that the manufacturer will not own up to either live with it or as I recommend to my customers replace the faucet with a better more reliable brand.I wish there was a better solution
