Question about Dewalt 6.3 Amp Dry Wall Screwdriver
The bit in my Dewalt 6.3 Amp Dry Wall Screw gun will not pull out, how do I get it out to change it and how can I change from a Phillips to a nut driver tip.
Posted by dickfaulkner on
Fred Yearian
  • 5,603 Answers
The bits are held by a spring snap ring that sometimes takes a lot of force to release.
Spray a little bit of CRC226 into the bit/chuck interface and grab the bit with a set of visegrips and PULL !!!
The CRC226 is available in a blue spray can at Home Depot in the electrical dept and fights rust. A can is about $2.70... make sure to get the 226 as there are other CRC products there.
Posted on Jun 27, 2010
How to change bit on drywall rooter dewalt
ROUTER????you should have two wrenches or one with a locking mechanisms on shaft----loosen nut----push bit in then pull out!!!
if doesn't work take the nut off and check the holding collar---possibly spray it with penetrate---tap it a few times & it should come out------GL
Dec 25, 2016 | Dewalt Drills
How do I replace the bit? On Dewalt screw gun
You pull it straight out - just a small clip that holds the bit & the bit holder in place. If it has been in a while you may have to grab pliers to pull it out.
Sep 28, 2014 | Drills
Hi, my hitachi drywall gun runs good but the bit dosent spin, it dont screw. any idea. thanks
drywall guns wont spin until you put pressure on the tip, load a screw and put it to the wall (or whatever) add pressure and pull the trigger
May 08, 2011 | Hitachi W6V4 4500 Rpm DryWall Screw Driver
I bought a DeWALT adjustable depth screw setter. How do I remove the driver, the Phillips bit tip itself, and replace it with another size bit?
usually you have to grip it with a pair of vise grips and PULL, sometimes the magnetic driver will come out also but all you need to do it push it back in till it clicks.
Apr 23, 2011 | Dewalt DW2043 Adj Screw Depth Setter
What's wrong with my screw gun when the bit keeps falling out when in use?
The bit holder resides in the clutch housing which has a collar with a ball bearing that the notch in the bit holder snaps into. It would seem that the ball bearing has slipped out of the cooler on the clutch housing, therefore nothing is locking it into placed. If you need a diagram, let me know.
Apr 30, 2010 | Dewalt Versa Clutch Tek Screw Gun DW268
Replacing the driver tip on Dewalt Dry Wall Screw Gun
yes,when you look at the front portion of the gun, the tip nozzle thing is actually two separate external parts. The foremost aluminum nozzle and the twisty black plastic thing behind it will pull straight off the piece that is reverse threaded onto the gear box.
Apr 08, 2010 | Dewalt 6.3 Amp Dry Wall Screwdriver
Was given a drywall screw gun to use, but I need to change the bit to fit smaller star drywall screws. How do I remove and replace this screw bit?
I use a DeWalt and the bit should just pull off like you would a cordless drill/driver. You might need a little persuasion (vice grips or pliers) because of the constant torque placed on it.
Mar 02, 2010 | Drills
Adjusting the depth of a dewalt dry wall
you should just have to turn the collar, it is marked with which way to turn for deeper setting of the screws. You can go to Dewaltservicenet.com with your model number and download a copy of the owners manual for more specific information.
Jan 02, 2010 | Dewalt Drywall Screw Setter 50 Pk Part No....
Cord replacement
try this web site .you will need your model .number http://www.toolpartsdirect.com/dewalt/dewalt-18.html
Mar 11, 2009 | Dewalt 6.3 Amp Dry Wall Screwdriver
Dewalt 6.3 Amp Dry Wall Screwdriver Logo
5,710 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
efs_perpends
efs_perpends
john h
Tim Venetis
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
