Zenith P42W46X 42 in. Plasma EDTV Logo
Posted on Jun 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a zenith p42w46x. It was given to me by a friend as it stopped working. You plug it in, the red power indicator on the front is on. Then you press the power button and hear a click, the light becomes yellow and stays on for 5 seconds, then changes its color into green and stays for 10 seconds. Then goes a click again and the light becomes red again. That's it. The screen doesn't show any signs of life as well as the sound. Please advise.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 117 Answers
  • Posted on Jun 27, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
117
Questions
0
Helped
24171
Points
174
You need a rebuilt power board
1helpful
No power no picture no sound
I assume there is power in the power outlet. Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Need Zenith control code to program universal remote
Hello
Three digit universal remote codes for Zenith TV are:
000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/ 153/ 0016/ 0017/ 0092
Four digit codes are:
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
OK.
2answers
How do i turn the television on i just bought it from the store
Either by your remote or manual. Some models have a master rocker switch close to the ac input where your cord plugs into. That kills all power to the set for vacation purposes.
Dark and snowy Screen on my Zenith Plasma
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
2helpful
Multiple vertical lines on screen.
Hi I am Vortash Although this is trademarked as a Zenith the manufacturer of this set is LG and the prefix P42W46X is one of their set product numbers and is actually one of their RU-42W46X 10/11/12 -series televisions . The problem you are describing may be either incorrect display setting or incorrect picture fomat letterbox .. 4.3 pan or 16.9 widescreen I am guessing you do not have the manual for this set and I have found one on this site http://www.safemanuals.com under the LG P46W46X prefix FREE it may help you to solve this.
Another problem it may be is a power supply fault , components under heat conditions cann change value and restrict power flow causing many different faults this is particuarly true of semiconductors prior to failiure ..Try adjusting the set according to the manual and if this does not cure the problem I am afraid you are going to have to get the set looked at by an engineer . Regards Vortash
TV turns off after about a minute flashing red light on lamp indi
your tv is talking to you basically, is telling you that the lamp has to be replaced. this is a common problem with this dlp tvs, when the lamp is bad the shuts off within minutes, so just replace the lamp my friend.
1helpful
Zenith P42W46X 42 inch EDTV
common problems with these, usually customers here a loud pop. then the screen goes blank. I would try...
Some of these have a 4 pin test on the control board that you can jump with solder to get test pattern. If you get it to do that then these boards maybe good and would replace the control board. if nothing happens, then
the upper & lower drive also the Ysus and Zsus boards all at the same time.
last could be a defective panel.
hope this helps. p/n are on all the boards.
Picture on big screen
Chances are, if it's an older set, componants have changed value through use over time, which also includes the picture tubes and associated driver circuits. The way to compensate for this color drift is through adjustments. Either turn the red down a little, or turn the blue and/or green UP. Be carefull though as there are potentially dangerous voltages in and around the circuit boards and picture tubes.
Plasma Screen not working only sound
It might be one of the power supplies. There are three in this model. One for the sound, one for the video, and one for the computer components. The video power supply is probably shot. They cost about $200 a peice from LG. If there was a "pop" sound when the video stoped, then it might be one of the circuit boards in the back. Yet again, they are three, each costing around $200 from LG.
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
