Nikon COOLPIX L4 Digital Camera Logo
Posted on Jun 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I upload pics they come out funny on the computer. It looks like the picture was cut in half and put back together or I should say put back like a puzzle and arm here and a head here it is like they do not line up. Is that a camera problem or a computer problem. The pics look fine on the camera. It is once they are uploaded is when the problem happen. I have Windows XP I just need an answer I am frustrated.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jun 27, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197897
Points
38521
As an experiment, take the card to a store like Walmart that has a Kodak Picture Kiosk machine. Insert the card and print a couple of the pics. Are they ok? If so, the problem lies with your computer.
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Pictures downloaded from sd card onto computer are being cut off!
its a matter of resolution ...just download them on the computer ..and modify them on a picture manager like photoscape... actually just make them a little smaller or change the resolution on the computer .. what happen is that the picture is somehow larger that the machines you tried supports ..
Cannot upload pictures from LG Shine phone to computer
If your pics are on your card for sure than you may half to remove the card and connect it directly to your computer. The file may have been
saved to the wrong part of the card. This may not be the answer but it
has happened to me in the past. If you have not saved the pics to the
card that is your problem. You must save the pics to the card and try again. You should be able to select a pic and move it to the card.
after you do either of these two ideas you should be able to move your
pics to your computer. hope this helps.
Pics have lines through them changing pic dark
This is not a solution, but how did you get your pictures onto Windows Vista because I've been trying to look for a solution and since you said you had some success, I could really use your help.
2helpful
2answers
Canon Powershot SD1000 Uploading Pics To Computer Problem
ugh this happened to me too :( it sucks cuz i have had great pictures i wanted to upload but they wont upload :(
Memory card
use a sd memory card reader-no software-plug and play-make sure you don't have 2 folders in camera storing pics in different places-check in menus for folder numbers
13helpful
2answers
Lost Pics
Memory card error is common problems in various sd cards and cf cards. I took a closer look at my little SD memory card. It has a sliding lock on it to protect data. Check to see if the card works when you slide that lock up or down. Read more about memory card:
http://www.uflysoft.com/data-recovery-mac/memory-card-error.html
Upload pics to camera from pc
Just use a external memory card put it into your computer and paste it on the card. Then put the card in your camera. Even though you have changed the way the picture looks. It will still go back onto the camera.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
