Re: Craftsman Electric Pressure Washer 1800 psi. Start...
The motor overload / thermal protection is likely the cause. Check your hose and wand / nozzle for restrictions. Is this the same hose and wand that it shipped with, or is it from another machine?
Your local Sears store can get you a user manual and diagram for our pressure washer for further troubleshooting.
Good news - you shouldn't need to return your machine! Dyson Digital Slim cordless vacuums have two power levels - high suction power mode for regular vacuuming, and Boost mode, which provides 6 minutes of highest suction power for tackling tougher tasks.
It sounds like you're using your machine set to Boost mode, which will reduce runtime to around 6 minutes. To change back to normal power, hold down the on/off trigger so the vacuum is running. Then at the same time, press and release the round illuminated Boost button on the rear of the machine.
I'm confident this will resolve things - if not, Dyson experts are on hand to help. You can reach the Dyson Customer Helpline for further assistance by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
From what you've described, it sounds as if you may be using your DC59 set to Boost mode. This will provide 6 minutes of highest suction for really stubborn dirt, but for regular vacuuming normal mode should work effectively.
To switch back to normal mode, ensure your machine is fully charged (this will take a maximum of 3.5 hours), then hold down the on/off trigger, and at the same time, press the illuminated Boost button on the rear of the machine.
You might also find our Getting started guide useful:
I'm confident this will resolve the issue, but if you would like some further advice from our experts after giving this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Maybe open the motor casing and look for an overheat reset button. If it doesn't have one, check for voltage at the wires coming directly out of the motor. If it has power there and no reset switch, then the motor needs replaced or rebuilt.
I would take it to a proper repair facility (Sears. I used to work at their Harrisburg Repair Center). They are trained to work on equipment like this.
you forgot to say if it is a 3 phase machine
if it is 3 phase then a phase in the unit is overheating and that will stop the machine then blow the breaker as all phases have to draw equal current
if it is a single phase then the start/ run capacitor or centrifugal start run points are not breaking at speed and so the start windings are overheating and causing the breaker to trip
Take it to an electrical motor rewind shop and have it properly tested with test equipment
