Hard disk error
I have ir 3300, which is showing bellow code-ooo-602, so please tell me the solustion. youcan do mail me [email protected]
SOURCE: E00002-0000 error code
ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
SOURCE: USA - COPIERS - IMAGERUNNER 2230 Copier: canon IR 2230 r giving me an error E000024-0001...
eroor 000024-0001 error is found in cannon ir 2870 machine, how is solve the problem
