Logitech Cordless Mouse Logo
Question about Logitech Cordless Mouse
I need to change my batteries and i cant figure out on how to open the cover to the batteries
Posted by Jessica Grutt on
Anonymous
    Problem Solver:
  • 16 Answers
Try going to : http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
You should be able to find the manual here.
Posted on Jun 27, 2010
How do i change battery
1. Pull the battery cover off (away from the base) in a downward motion.
2. Install one new "CR2032" battery into
the battery compartment, with + facing
outward.
3. Replace and fasten the battery cover
securely.
27helpful
2answers
How to change key fob battery in 2010 mazda cx 9?
I just figured out how to change the battery in the Advanced (keyless) fob for my 2010 Mazda CX9. You just need to take out the physical key, and use a small flat-head screwdriver to pop off the back cover. Then there is a black battery cover with an o-ring that just pulls up to reveal the CR-2032 Battery. Here are some pictures to explain better:10_10_2012_2_13_28_pm.jpg
1helpful
2answers
I have a wireless optical mini mouse model #98792. i cant figure out how to open to install new batteries.
these usually have a button on bottom with a picture of a mouse push that it will open the top where the batterys are.
208helpful
3answers
I have a Microsoft Bluetooth Notebook Mouse 5000 and i need to change the battery. I cant find any latch or button to open the mouse to put new batteries in it! I looked on the MS site and found nothi
There is actually no release button on my 5000. Between the white on-off button and the bluetooth synch button there is a finger notch. If you put your index finger in the notch (pointing toward the base of the mouse you can put your nail under the lip and the batter compartment opens right up. There is a horizontal slot in the battery cover - trying to pry that open does not work. The whole thing is well-cloaked but surprisingly easy when you figure it out!
How do I change the batterys in my notebook laser mouse by hp
The gray cover slides forward and exposes the batteries. If you cant figure it out, take it to BatteriesPlus and they will do it for you. www.batteriesplus.com
9helpful
2answers
976LM Security plus Wireless keypad
It took a few minutes, but I figured it out. At the bottom of the keypad is a small half round hole. Insert a punch or anything small enough to fit in the hole. Press up, while prying out the bottom of the cover. I have a Liftmaster door with a wireless keypad. If you have the same pad this should work.
8helpful
How do I release the battery clip on a Timex Expedition watch to change the battery.
I just had this problem, and my 8 year old and I had to fiddle a bit to figure it out.
Just to confirm, you have removed the back cover and taken the watch guts out of the face and strap assembly and are looking at the battery which has a cover over it and maybe a sticker on the cover that says "unlatch to remove battery", with two >'s, one pointing to to each side?
On each side there are two small metal tabs, which surround a small moulded-in plastic piece with an opening in the middle.
The release is in that opening in the plastic piece. You need to fish around in that opening a little to catch the release and push it outward toward the edge of the watch (away from the battery). You need something very small to do this with, like a straight pin. If successful, the cover pops up on one side and then you do the same on the other side.
Good luck.
3answers
How do i rechager battery
its to the right of the buttons when you open up the screen. pull open the plastic cover
2answers
Nikon Pro Staff 440 Range Finder
there is a silver quarter sized screw out cover on the battery compartment.  It has a slot so you can use a coin or screwdriver to remove the cover.
Top Logitech Computers & Internet Experts
Marvin
Marvin
Steve Nordquist
Steve Nordquist
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
