Audiovox BA200 Car Subwoofer Logo
Posted on Jun 27, 2010
Pin out diagram for a Rampage Ba200 Subwoofer.......6 pins please..
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual
Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html
Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay
I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
Colour code wiring diagram
Pin 1 - Signal (Green/Yellow) Pin 2 - Signal Return (Grey/Red) Pin 3 - Signal (Orange/Red) Pin 4 - +5V Reference (Orange/Yellow) Pin 5 - Ground (Black) Pin 6 - Not Used
8helpful
Wireing diagram for Dell A525 Zylux Multimedia Computer Pc Speaker System W/subwoofer 2.1
pin 1-G
pin 2-R in
pin 3-L in
pin 4-PG
pin 5-R out
pin 6-ST BY
pin 7-VC
pin 8-L out
pin 9-PG
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Need to connect a 6 cannel 9 pin audio cable subwoofer to a standard audio receiver. is there an adapter to make it plug into rca javks?
Nothing commercially available as the pin-outs are all different and 9 pin din is a non standard connector. Contact the manufacturer directly and ask tech support for pin out diagram.
1helpful
Does anyone have the pinout for the subwoofer cable
PIN 1 L. PIN 2 R. PIN 3 SL. PIN 4 GRD. PIN 5 SR.PIN 6 SW.PIN 7 C. PIN 8 P.ON
12helpful
2answers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
19helpful
Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
