Question about John Deere Garden
I have a john deere riding mower model L100 it runs good but after 20 o 30 minutes gas stop going to the engine after it cool down it start running again does this mower have a gas pump
Posted by mlumbrer2000 on
Bill Linda Rivard
  • 197 Answers
When it dies loosen the fuel cap and see if it will start.If it starts its because the tiny vent hole in the fuel cap is plugged.
Posted on Jul 07, 2010
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Mar 05, 2016 | John Deere L100 Series
Kawasaki 17 hp stalls when hot
you need valve job done and new valves put in and i said new valves do not use old valves again 150.00 per cylinder
Sep 07, 2014 | John Deere Garden
I used my John Deere L110 Lawn Tractor all day yesterday. Turned the engine off, it popped. Then went to start it today and it just pops, seems like the timing is off.
throttle down your engine before turning it off . this reduces amount of fuel going into a hot engine ,just a few seconds before switching key off , should stop back firing issues.
Sep 09, 2013 | John Deere L100 Series
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
My john deere L111 riding lawnmower starts fine but after running for 20 minutes, it just shuts down. Will not restart until it cools down. Any suggestion where to look.
I had this same problem with my John Deere LA140. I suspected that it was some sort of fuel delivery problem. Long story short, it turned out to be the gas cap was not venting properly, creating a vacuum in the fuel tank. The temporary fix was to loosen the cap when it starts to die. This relieves the vacuum and allows the gas to flow again. Installing a new cap on the tank fixed the problem.
May 05, 2011 | John Deere 22HP VTwin 48" Riding Mower
My John Deere L130 riding mower quits after it has been running
A John Deere repair guy showed me how to fix this. It is very simple. Remove the gas cap. Pop out the liner in the gas cap with a thin pocket knife. Clean out the cap. From the top of the cap, where it comes to a peak, take a very fine point (even a small knife blade will do) and make sure the little hole in the top (that you didn't know was there) is clear. The engine is starving because the gas tank is not properly vented. I suffered with this problem for two years until he came to sharpen my blades and I asked him about this. A two minute, free fix did it and I have never had problems again.
Jul 26, 2010 | John Deere Garden
Riding mower does not seem to be getting gas
yeah.. the carb needs to be cleaned and rebuilt that is an easy job so if your a DIYer this will save you loads of money. just buy the rebuild kit..good luck
Apr 06, 2010 | John Deere 420,1020,2010,2020,2510,2520...
After the mower gets hot, it shuts down.
my john deere did the same thing i had spark and it did run,but the coil heated up an there was a short in it and it would stop and you wait awhile and it cool down and it would start again,i replaced the coil and the problem was gone.
Sep 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Engine starts and runs Great. When I engage the Pto leaver on my John Deere L100 the mower fails.
at the point of lowering the pto it's trying tosuck more air to mix with the gas .you might just need to change the air filter.
Jun 07, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
867 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
