Take the two sections apart, remove the seal and put the two sections back together.You will be able to see any gaps if they are warped. A straight edge might work too. Also inspect the surfaces for any cracks. The can get a hairline crack if the sections are tightened to tight, and the seal is out of the grooves. If all is ok, silicone the seal, silicone the grooves, then put the pump back together. This will help keep the seal in place. I just use a pool/spa sealer like Leslies Pool and spa lubricant.
