What power wire are you talking about? The lamp? If yes then one of the wires(lamp power wire) goes into the ballast. The other one is the lamp enable . The lamp sensor is located on the lamp cover itself and does not have a connector cable. I would like to have a look at the cables though to make sure we are both on the same page.
Above the lamp there appears to be a heat sensor relay that has a 2 pin socket...not sure where the 2 wires are to plug into and where the other end of the cable plugs into.
The BP63-00344A which is the thin rectangular box that the thin ribbon cable from the colour wheel assembly plugs into has a 2 pin socket that I believe a 2 wire (black/blue) plugs into on the back side and I believe plugs into the small power ditribution board that the cooling fans are plugged into.
This plug can be inserted in eiterh inverted position and if polarity sensitive I need to know if the tab position is up or down.
I also need to confirm which power plug goes where.on this same board. I have assumed that the two cooling fans are side by side at the back of the board and the black/blue cable is at the front...is this correct?
do you have the wiring specs for the main board that feeds the lamp, colour wheel assembly and projector?
Gord
Jun 26, 2010 - Above the lamp there appears to be a heat sensor relay that has a 2 pin socket...not sure where the 2 wires are to plug into and where the other end of the cable plugs into.
Gord
I got the message, I meant an image so that I can guide you through this. In the mean while I will see if I can find you a service manual.
PS: You may not be able to upload the image here so please upload it to imageshack.us and get me the direct link
Hopefully you can find a manual...'cause I put everything back together for the time being unti I get some new parts whic if you have any advice where to find a colour wheel for not too much that would be great!
My camera has also been misplaced so I will see what I can do about pictures....
thanks for your help
Gord
I could find the service manual. However not for free. It costs 12.99$
http://www.service-manual.net/ashop/cata...
Its
the second one from top.
