Is it the fill setting switch?
Most likely it is the clear rubber hose that connects to that switch. IF you pop the top up you can llok and make sure it has not come disconnected from the side of the outer wash tub.
Top comes up by depressing two spring clips located between top and the front panel and will flip up like a hood on a car.
Follow the clear hose and be sure it is attatched to the tub and that there are no holes or cuts in it any where.
IF the hose is ok and attatched at both ends, then I would replace the pressure switch (load size switch).
Good luck! Hope this helps you.
