Water Heaters Logo
Question about General Electric Water Heaters
Light flashing - lockout condition - ECO failure
Posted by casowers5647 on
Anonymous
    President:
  • 1,015 Answers
The ECO is designed to shut off the water heater in case of the water heater overheating. This is to prevent the water heater from exploding. I assume that you have a newer style residental water heater or a commerical boiler. The ECO is a fuseable link that is built into the control and located at the thermostat probe. If the water heater overheats then this link will melt cutting the circuit on the millivolt system(residential) or 24volt system(commercial boiler). If you look under the water heater control(where the temp adjustment is) there are usuall two wires that go from the control to the water heater. These are the ECO wires. Verify the wires have not been cut or damaged. If these wires are cut or damaged then the ECO circuit will be incomplete and you will get the ECO lockout failure. Also make sure that the flame lock-out switch is not tripped. It will be located at the burner compartment cover and have two wires going to it. Most have a little button in the center. These are to sense high heat and one might have tripped closing the circuit. You can push this little button to re-set the switch. If you feel a little "click" then the switch was probably tripped. If it does not have any button then it might be "self resetting". To test that switch use a continuity tester and the circuit should be closed. If these switches are working then the fusable link for the ECO is probably bad from the water heater temp getting too high or was defective and failed. This will require you to remove the water heater control valve and replace the fusable link. If you do not have experience with this I suggest you call a licensed plumber to make the repairs. If this repair is improperly done it could void the warranty on the water heater and/or cause property/personal damage or injury. There is a possiblilty that your water heater thermostat had failed causing the ECO to trip. If that is the case then the ECO safety did it's job.
Posted on Jun 26, 2010
2answers
What does ECO failure mean on my hot water heater?
I'm guessing about model. I Goggled Eco failure. For reheme this site and discussion may help. http://terrylove.com/forums/index.php?threads/ge-rheem-power-vent-eco-failure-code-gg50s06rvj.43646/
but since it's gas, and an expensive unit I'd call the installer or his service.
Led blinking 5 times
what brand and model
what product
http://waterheatertimer.org/How-to-fix-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
How do i reset the lockout
Push and hold the button for 60 seconds. It is in customer lockout because it was pressed more then 3 times.
Pr sw failed to close
Troubleshoot by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Repeated 3 flash on power vented honeywell gas control thermostat means system in lockout.
Repeated 3 flash on atmospheric-vent Honeywell gas control valve means temperature sensor failure.
Take apart gas control, and buy temperature sensor if sold separately at AO Smith dealer.
http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.html
Add a comment with more information
Pilot light will not stay lit on GE 40 gal. gas water heater tank
You have tank-type gas water heater:
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Hot water heater pilot is off. It's not gas,
Open following link to watch thermocouple replacement.
Make sure new thermocouple sits into pilot flame. Instructions for relighting water heater are usually printed on side of tank.
http://www.youtube.com/watch?v=v0aBPsNg6vo
ECO failure. Replaced the gas control thermostat & vapor sensor
It sounds like your gas/air mixture needs to be adjusted. The flame should have just the slightest amount of white, at the very tip. The rest should be evenly blue. There is an air vent adjustment in the line to the burner, right after the gas input.
ECO Failure
make sure your flue is clear,, and no suit is in the burner, also there are wires going to the ignitor make sure they are not touching after time for what ever reason they need to be seperated because they short out but doesn't cause any problem other then the unit not lighting
Eco failure
pilot will not ignite and eco failure code on high efficiency water heater, with electronic ignite
Top General Electric Water Heaters Experts
RJ H2O
RJ H2O
Paul Carew
Marvin
Marvin
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
