i dont think wwe games run perfectly in dell inspiron mini because they require high memory graphic card and dell inspiron mini does not have high memory graphic card....minimum 512 mb graphic card is required to run wwe games perfectly....may be you should try older wwe games.
if you play 2011 games pl z check your graphic card property because this game need lot of graphics.that its your games give a lot of pressure of your processor & your PC has been heated. you meet your hp shop dealer & check it a problem.if you possible you perches graphic card (250M nvidia) & install it.
Hey there, this is a common error on fifa 11 when trying to run the game from a laptop or even a desktop that doesn't have a graphics card that supports "shader model 3" or better. Your graphics card just doesn't have the requirements to play the game. You can try to update you graphic's card drivers and see if that works and even get the newest version of Direct X and try again, see if that does the trick! good luck!
-Ryan
hey first of all tell which game then second thing iz that for latest games to run fine on ur pc u must hav a good graphic card.at least 1GB dedicated memory
if you dont want to have to upgrade your power supply. your pc only has a 350w in it. i would suggest the Nvidia 8800 GT if you dont have a budget or the 8800 GS if you dont want to spend too much. both run 512mb and are superb for gaming. make sure you get some extra cooling in your pc so as not to overheat, these cards put out quite a bit of extra heat. both are compatible with the dimension 8400.
Go to http://www.ati.com and get the driver there. It will be a file download. Just save it to your hard drive and run the program after the download is complete.
plz visit the mother board manufacture website (if you are having branded machine then you go the the manufacture website) and download the drivers. plz note if you are using any graphic card then you have to visit the graphic card website. plz post your comment
its excess heat check the nvidia monitor if it exceeds 65-70 degrees celcius.Firstly take precautions turn off computer from main switch press power button for 5-10 seconds make your hand touch the surface of the unpainted metal part to discharge static, Remove card (Found in manual).If it seems quite hot you can remove the heat sink by pressing in the plastic clips on the bottom and dust it off with a medium paint brush, BECAREFUL OF THE POWER CORD. you could use compressed air and blow under the heat sink and see to dust it off
