Sony VAIO VGN-NR385E Laptop Logo
Posted on Jun 26, 2010
The left button of Mousepad(one on laptop, but not touch pad) is often not working and sometimes need to press hard. Model VGN-NR38M, Sony Vaio. please help
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
850
Points
6
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
283
Points
What is part number required to fix the bad micro switch problem on SONY VGN-NR385E
I have bought a sony vgn-n38e anf i am not able to scroll up or down on the right hand side of the touch pad, i would like to know if there is simply a button to press to rectify this or if it is possibly...
So you need to update driver for this touchpad scrolling error.
Please click on the below link
ftp://download.sony.com/US/pc/ALDOTH-00199336-US.EXE
This will download the driver for your touch pad then you need to run the driver that you downloaded.
Then restart the notebook
Check whether it is working.
you can find other drivers for Sony Vaio VGN-A790 on the below link.
http://www.notebook-driver.com/sony-vaio/sony-vaio-vgn-a790-notebook-windows-xp-drivers/
Hope this resolve your query.
Kindly provide your valuable feedback for this answer
Thanks.
Left mouse button of Sony VGN-NR38M (nt touch pad) is not working often, and some times need to press hard, please help
mcdevito75 here, Bring laptop to Staples, Best buy for testing, sounds like that key could be hanging up. maybe some sort of oil needed.
PC's mouse is not functioning properly
http://www.sony.com/index.php
go to services and support and download the mouse drivers
Touch Pad and mouse buttons
try it with toggle keys it may be work
My laptop left mouse button has stopped working
Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
WildeFalcon
7helpful
2answers
Driver av mode sony vaio VGN-CS215J
im from malaysia and bought it from malaysia, my laptop is vaio VGN CS36GJ.. im having the same problem as stated up there.. my touch pad of sound, av and capture button is not function.. can u please tell me where should i go or what should i do?
2answers
Sony vaio touch pad not working.
i have sony vaio vgn-sz58gn model laptop with windows xp installed. but on touchpad whenever i move cursor to up, it goes to down. if u move cursor to down, it goes up. can you provide me solution pls for that?
Awaiting
1helpful
2answers
Malfunction of the left button of the touch pad
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .Hey it's a Cheap laptop and uses cheap parts.
11helpful
6answers
My Vaio touchpad started behaving strange. I could move the curser, but no response on left or right click or double tap. Also found that in any search field or user name fields, the computer would just type endless 9's. My wireless mouse could operate the left and right click buttons, but not move the curser. A suggestion to get the mousepad operating again was to touch any key on the keyboard. This allowed it to function again. Final solution was to remove the battery, then hold down the start key for about a minute, reinsert the battery and start it up. It seems to have resolved the problem. I have a 3 month only laptop with Windows 7 already installed. Hope this helps.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
