Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
I turned off my ice maker with the switch on the ice maker now it wont turn back on. Is there a reset or a way to reset the ice maker
Anonymous
  • 1,056 Answers
How did you know it is not on? A single cycle for an ice maker takes some time to complete. They don't have reset buttons. You just lower the arm to turn it on and raise the arm to turn it off. The cycle goes like this. The tray is filled with water then as the water freeze it reaches a temperature that which triggers a sensor. Then a heating element melts the bottom of the ice then the mechanism rotates and dump the ice. Cycle starts again. This single cycle can take a few hours to complete. If the cycle is interrupted by turning off the water, it could take a while because the ice maker will go through the cycle regardless.
Posted on Jun 26, 2010
My Mr. Freeze portable ice maker turns on but the water is not being delivered to the ice tray.
https://icemakershub.com/ice-maker-not-working/
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Kenmore Ice maker; To reset, shut down the unit and unplug the cord from the socket. Wait for 5-10 minutes to plug your ice maker and start the ice maker by holding down the power button.
https://coolersjunkie.com/portable-ice-maker-wont-make-ice-troubleshooting/
2answers
The Ice maker is not making ice. The water is on is there a reset button?
No Reset call the manafacture or go the Store where you bought it and get an Exchange sound like its defective
1helpful
I turned the ice maker off "accidentally" when I switched from crushed to cubed ice. Despite both pressing the reset switch and unplugging the power several times, ice maker won't come back on. Am I...
Something may have broken behind the dispenser control panel. Like part of the switch control or a micro switch, What is your model number? Can I try to help you? Thanks Sea Breeze
Icemaker
this is a test, if its a new er model, turn maker switch off for 15 seconds,turn on move the flap arm below the maker bak and forth 3 times waite 3 min, this should reset maker
Hoshizaki KM-600mah beeping
PCB requires to be reset. White button power needs to be on or it wont reset.
Hi, my model# is psi23scna. the whole unit
Check all your pin plug connections and then unplug the refrigerator for about 20 minutes with the ice maker turned off. Plug refrigerator back in and then switch the ice maker switch back on. This should reset board and ice maker which is also electronic. If this works let me know if not then tell me and i will send you the service manual. You either have a loose connection from board or a defective new board or electronic ice maker. Or just may need to have everything reset so they know they are connected to the new motherboard, Sea breeze
1helpful
Ice maker very slow to make ice
there may be some thing stuck in the ice machine try checking it out
6helpful
GE Icemaker PFSS6PKXASS
To reset the filter light you need to hold the button in for 3-5 seconds , the light will usually flash while you hold the button down then it will go solid and then go out once you release the button. The ice maker will only make ice when the freezer is cold enough approx -14c . Did it make ice ok before ? There is the possibility that when changing the water filter air got into the system and has not bleed out of the ice maker feed tube yet.
The Ice maker can usually be put into a test mode by turning it off , wait 30 secs then turn it back on and press the ice level sensing paddle back three times within 15 secs of switching the ice maker back on . The ice maker should then go through a forced harvest cycle and ask for water at the end of it.
Hope this helps
1helpful
General electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
4answers
Samsung Ice Maker on Mdl RB215LASH
the electric motor for the ice-maker is not turning...why? try disassembling and power motor with 115VAC cord from wall plug...be careful-ensure frig unplugged...using alligator clips...does it turn...can you hear it...it should turn VERY slowly.
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
Top Frigidaire Refrigerators Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
