Televison & Video Logo
Anonymous Posted on Jun 26, 2010
Blocks of Colour displaying
I bought a display model/factory second Samsung LA40N81BD, it initially worked well, but after a few hours began displaying only range of different colours repeatedly, from a bright pink/purple, to green, to blue, to red and then to a block of 4 horizontal lines, from the top down: red, green, blue, white each taking up around a quarter of the screen.
While it was doing this nothing is displayed, not even the TV menu, though sound is being output correctly via optical cable, and the remote is responding (can hear channels changing etc)
after a few hours it started working normally again, and after being turned off overnight is just doing the colours blocks again.
Azrael SRL
Level 3:
  • Samsung Master 11,800 Answers
  • Posted on Jun 26, 2010
Azrael SRL
Samsung Master
Level 3:
Answers
11800
Questions
0
Helped
2566464
Points
35672
 This tv has severe problems in the image processor - you bought a dud. Try getting your money back.
Testimonial: "Thanks, Azraelsrl! "
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Factory reset for ht-q20??
1. RESET
While "NO DISC" message appears on the display of main unit, hold the main unit's STOP button for longer than 5 seconds. "INITIALIZE" appears on the display and all settings will return to the default values.
Using the RESET function will erase all stored settings.
2. Firmware update
Upgrade File ver 1.3, All OS (ENGLISH) 18 Sep, 2007
Upgrade guide ver -, All OS (ENGLISH) 21 May, 2007
HT Q20
7helpful
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
4helpful
3answers
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 • Freezers
4helpful
2answers
Forgot password to Samsung SMT-190DN
Hold the remote control's STOP ( ) button for
longer than 5 seconds. “INITIAL” appears on the display and
• Press the POWER button.
Do not use this unless necessary.
M4202 shows "Initializing" message for 5 sec. and blocks itself
This is the firmware going bad.
You need to go to the RCA website and download the firmware for your player.
After you download the firmware.
Connect your mp3 player to usb device of your pc.
Then install the the newly downloaded firmware.
4helpful
Setting the clock
Setting the Clock for Systems with the
Set Button
Press SET. Within five seconds, press and hold the right
SEEK arrow until the correct minute appears on the
display. Press and hold the left SEEK arrow until the
correct hour appears on the display.
Setting the Clock for Systems with HR
and MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
