2004 Chrysler Sebring Logo
Posted on Jun 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2004 2.7 6 chrysler sebring lxi. ac blows really cold and periodically just starts blowing warm air. is there a relay or temp. sensor that might be going out and through a malfunction shuts down the ac to protect the compressor or motor.
Anonymous
Level 2:
New Friend:
  • Expert 104 Answers
  • Posted on Jun 26, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
104
Questions
Helped
34203
Points
230
Cooling fans working? If you notice the air getting warm mostly while stopped, probaby cooling fans not turning on. if the fans are working properly, may be low on freon and need a recharge.
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Why when I start my car is there an odor coming from vents that smells like something is burning, and my Air Conditioner still blows, but it only blows out hot air. 2008 Chrysler Sebring. Help?
have an accredited ac shop as an ac cannot produce hot air only cold air so that means that the ac is not working (leaks low on gas etc). The hot air is from the heater in the car and the smell is probably wire overheating or the resistors are burning.
1helpful
4answers
2004 sebring air conditioner stops and starts
Low freon will cause the compressor to short cycle, when the compressor runs the pressure in the low line is pulled down and the low pressure switch turns it off. Not running the pressure builds up and turns it back on. In the old days there was no low pressure switch, with no freon to carry the oil the compressor was destroyed.
1helpful
I have a 2001 sebring convertable 2.7 V6, when I have the headlights on my heater is blowing cold air, turn them off and hot air blows, the dash lights at the temp knob and the fan speed knob are also...
I would expect this is more to do with a low coolant level than an electrical issue. If your coolant is low when you turn off the headlights your engine revs will increase slightly increasing the pressure in your coolant system and pushing fluid into your heater core.
Check your coolant reservior when your car is cold (first thing in the morning), it should be at max cold. If it is lower than this you may not have warm coolant in your heater core.
If this is the case...then where did your coolant go?
Most likely the thermostat/temp housing is leaking...replaced both on my two 2001 sebrings...common issue..~$150 for parts and a little awkward to install but fairly easy fix.
1helpful
My 2004 Sebring heater only blows warm air when the car is moving. If I stop at a traffic light or put it in park it blows cold air. Any ideas?
1st check the coolant level. If it's low, what you describe will happen. If level is ok, let me know, and include info on engine temp gauge--how long to warm up, is gauge at warm up low temp range, normal, or hot?
My ac only works part of the time
u have a temp door accuator motor shorting out
My 2003 sebring go from hot to cold temp. the car will heat up then cold air start coming out
Two things . 1 - Make sure your antifreeze level is correct and 2- when at idle 6-700 RPM these cars do tend not to blow a lot of warm air. If this doesn't help you might want to try a new thermostat.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
