Question about Echo CS400 18" Chain Saw
Chain brake jammed on Echo CS400 chainsaw
I just purchased a new Echo CS-400 chain saw. Prior to shipping the saw, the shipper removed the bar and chain. Apparently while removing the bar, they jammed the chain brake into the locked position. The brake lever (front hand guard) moves freely, but the small metal brake connector that engages the hand guard is jammed forward and won't release. I've opened up the clutch cover where the chain brake mechanism is located, but can't see anything wrong.
Posted by barrywerner on
drallim
    Brigadier General:
  • 4,088 Answers
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Posted on Jun 26, 2010
Remove bar stud on echo chain saw. Cs 306 14 " bar
I don't quite understand the question but, If you are trying to remove the bar on your saw, First it should have come with a tool that looks like a screw driver on one end and, a wrench on the other end. Now!! turn the saw on its side with the Two Bolts facing you. You use the tool to loosen the bolts , just loosen !! next use the screwdriver end to turn the little screw inside the small hole just down from the bolts OK? Turn the screw , which loosen's the chain. Now take the bolts off and put them somewhere SAFE so you can find them when ready to put back on. Pull the plastic cover off , chain off, NOW YOU CAN REMOVE the BAR . I hope this is what you need.
Jan 11, 2016 | Echo Garden
Replace clutch spring
You need to remove the clutch assy from the chainsaw prior trying to replace the spring. Be aware that the clutch assy is no longer available so be careful not to damage it on removal.
Mar 01, 2015 | Echo Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How to install bar and chain on cs 310 echo
A CS-310 OM follows:
http://www.echo-usa.com/pdf/documentation/CS310es1112_042310.pdf
There is a very good, model specific, procedure beginning on page 12.
There are 2 listed based on serial number I think, you can download the other and an IPL here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 21, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
NEED TO FIND A NEW 14" CHAIN AND BAR FOR ECHO CS 305 SAW. NONE LISTED AT LOWES OR HOME DEPOT. THANKS FOR ANY INPUT.
What you are looking for is the following model bar:
Echo 14A4CD3752
If you cut and paste that into google or another search engine you will find numerous online retailers who can sell and ship you this bar for your CS-305 saw.
Apr 06, 2009 | Echo Garden
Purge pump removal
By studying an exploded parts diagram found online, I determined that it snapped out the top before the bracket slid out the front.
Jan 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo CS400 18" Chain Saw Logo
2,780 people viewed this question
Top Echo Garden Experts
colesmowers
Mike
bryan st
Are you an Echo Garden Expert? Answer questions, earn points and help others
