Question about Dishwashers
I have a ge dishwasher model GSD5211 purchased in may 2006. Water appears to be dripping from under the front ss panel to the bottom of thepanel. I cannot open it to check the source of the leak. Alo found that the leak occurs midway of the washing complete cycle. It also seems that the leak during a particular cycle. Not sure which as just two indicator lights stay on thepots and pans and heated dry. Please help
Anonymous
    Scholar:
  • 66 Answers
You may want to inspect the seal around the door to make sure it's not worn out or has some foreign material stuck to it causing it to not make a watertight seal during operation. If you don't see any problems there, then you should pull the machine out from under the counter to see if the drain hose has been damaged or dislocated. Most dishwashers are fastened to the bottom side of the counter by two brackets. Open the door to the machine and look at the top where it meets the underside of the counter to see how it is fastened. It's usually just two screws. Once you've removed the screws you should be able to gently slide it out and take a look at the drain hose. You may also want to take note of the condition of the floor below the machine to see if there is any long term water damage that either needs to be fixed or will give you an idea of the location of the source of the problem.
Hope this helps!
Posted on Jun 25, 2010
  • ginorama May 08, 2011
    any updates? having a same problem
Start light flashing. Dishwasher wont start
I'm guessing as you did not list the model number. Something similar happened on mine. Due to a freeze, there was a small crack in the inlet and water had slowly leaked. As a safety feature, the Asko has a tray under the dishwasher inside the overall dimensions. It has a float. When the float rises, the drain pump starts and the dishwasher will not start. In my case, the drip pan is not connected to the drain which gave me the drain sound, but did nothing to remove the leaky water.
I suggest you take the front bottom panel off the dishwasher and check for water/leaks.
Oct 29, 2014 | Asko 24 in. D3121XL Free-standing...
Ice/Water dispenser not working on my GE Profile Arctica model # PSS26SGPA SS. Does make ice though, just front panel stopped working. Called a tech to troubleshoot, who said it was the main...
Had same problem. Removed kick panel at bottom and found the wires from the freezer door near the lower hinge are very flimsy. The white wire was broken at the connector and the connector was corroded. Since I have no plans to remove the freezer door, I spliced the wires together with **** connectors and it's working fine.
GE could do better.
Jan 12, 2011 | GE Profile PSW26P Stainless Steel Side by...
Leaking from the front
I had same problem but different model #.
The part under the spray arm came lose and the gasket was hanging out. Causing it to squirt water right at the bottom of the door and leaking out. I took it apart put the gasket back in the groove, screwed it back down and is working great.
May 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
How do you open GE washer model WJRE5550H1WW? When my washer adds water, some of the water drips down towards the bottom of the machine.
on the front panel under the lid/top piece are two clips use a screw driver to push trawards machine and it will bring front panel towards you and unhinge piece wala! all exposed
Oct 01, 2009 | GE Washing Machines
Water drips from under door. the water is
There is a ventilator mechanism on the top right corner, behind the control panel / front cover.
******TURN THE POWER OFF AT THE BREAKER BEFORE STARTING, BE SURE POWER IS OFF ******
Open the door; remove all of the screws that hold just the front panel (not the controls panel). These screws are located on the inside of the door, around the outer edges. The front door panel will be able to be removed. Close the door with the front panel removed.
***IMPORTANT be sure nobody will come in contact with the exposed wiring (especially little kids) *********
Turn back on the breaker, turn on the washer, and run a quick rinse cycle. See where the water is coming from.
On my washer (same model) i had to replace the entire vent kit (sears parts ~$40.00) Call them with your model and serial number, or search online. Removal and replacement was very easy, and it did fix my leaking problem. Checked with the front door panel off and a quick rinse before I TURNED POWER BACK OFF and put the front cover back on.
Root cause?? From what I can tell, the solenoid stopper hardens over time, which allows for water from the spray arms to leak past.
Get it fixed now before you smoke the motor or control card. My part number was ABT35083501 be sure to double check model before purchasing.
Jul 17, 2009 | LG LDS4821WW 24 in. Built-in Dishwasher
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwashers Logo
263 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
