Question about Texas Instruments TI-30XA Calculator
- log (1 x 10^14) / 2.0 my question is how do you punch this in to a TI-30XA calculator. Please help.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
1 EE 14 LOG / 2 +<>- =
Posted on Jun 27, 2010
k24674
  • 8,091 Answers
Actually, you need no calculator to compute the value of the expression.
log (a*b^c)= log(a)+ log(b^c)=log(a) +c*log(b)
With a=1, b=10, c=14
log(1x10^4)=log(1)+14*log(10)
But as you well know, log(1)=0, log(10)=1
Your final result is -14/2 which is -7.
Posted on Jun 28, 2010
  • k24674 Jun 30, 2010
    OOPS
    log(1x10^4)=log(1)+14*log(10) should read log(1x10^14)=log(1)+14*log(10)
Change log base
The TI-30XA calculates logarithms to base e and base 10. You can calculate the log of x to any base b by calculating the logarithm of x and dividing it by the logarithm of b: log(x)/log(b) or ln(x)/ln(b).
Nov 29, 2013 | Texas Instruments TI-30XA Calculator
Change log base
The 30XA only calculates logs to base e (LN) and base 10 (LOG). However you can calculate the log of x to any base b simply by calculating log(x)/log(b) or ln(x)/ln(b)
Hi, how do i calculate log^-1 on my ti-30xa? for example, in order to calculate log^-1(-2), what do i do? thank you.
The inverse of the common log function is the power function with base 10 (10^). It shares the same physical key as the log. You acees the function by pressing [2nd] [log]
Sep 09, 2011 | Texas Instruments TI-30XA Calculator
How do you find the log of 9.01 using TI 30xA calculator?
To calculate the common (base 10) log of 9.01, press 9 . 0 1 LOG =
To calculate the natural (base 3) log of 9.01, press 9 . 0 1 LN =
Both the LOG and LN keys are on the top row of the keyboard.
May 09, 2011 | Texas Instruments TI-30XA Calculator
I need to use a TI 30Xa to evaluate a Logarithm Log5 1/625 Not sure how to use the TI to do Log5
Use the relation log5(x) = log(x) / log(5) = ln(x) / ln(5)
LOG ( 1 / 625 ) / LOG 5 =
or
LN ( 1 / 625 ) / LN 5 =
Mar 11, 2010 | Texas Instruments TI-30XA Calculator
-Log functions?
[+<>-] [LOG] [5] [EE] [+<>-] [1] [2]
Dec 17, 2009 | Texas Instruments TI-30XA Calculator
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
  1. Calculate the log 15.32 [LOG] [=] result 1.185258765
  2. Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Hope it helps
Dec 13, 2009 | Texas Instruments TI-30XA Calculator
TI-30XA
Use the inverse log key sequences "2nd LN" or "2nd LOG" depending on whether you are using natural logs or logs to base 10
Dec 10, 2007 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
717 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
