Tascam DP02 just got the tascam DP02..going thru manual...starting out...how to play demo song..did that,no problem...next page...navigation...instructions...press the "track edit key"the track edit menu will appear...WRONG..home menu apears with "song protected" on the screen...how am i to get the track edit menu up ?
Posted by mrtfw3 on
3 Related Answers
Ekse
  • 13434 Answers
SOURCE: just received my tascam DP02..manual
The song you have selected, the demo is protected, try anoter file.
Posted on Apr 15, 2008
Anonymous
SOURCE: tascam dp02
hi, might need your services in the future so i will save your site cheers . here is the fix which i found on a tascam forum ( press track edit and arrow up) this re instates factory settings . after i did that the (record) light and (play )light worked although there was no sound thru my h/phones when i recorded aaaagggghhhh switched off the unit fed up. the following day when i switched the unit back on every thing was ok .maybe it required to be shut down?? a bit like a pc, for all the corrections to be installed who knows it must be said that i am a technical buffoon i prefer hitting big rocks with big hammers ,this foray into high tech numbs my brain instantly and leaves me with a twitch .william
Posted on Jul 21, 2008
Anonymous
SOURCE: TASCAM DP02 CF
Try a seperate mike pre-amp, solved my problem. The output of both my dynamic and condenser mikes was too weak for the built-in pre amps in the DP02. Seperate pre-amps are also quieter than the DP pre-amps Turn the seperate pre-amps up first, then use minimal DP02 pre-amp. Good luck
Posted on Aug 29, 2008
Why does my casio p-45 piano only play one demo song? There are 16 available. I followed the instructions in the manual. Any ideas...?
Well friend,
According to page 24 of the manual here http://support.casio.com/pdf/008/ap_45_e.pdf
It says
Demo tunes
While holding down the MUSIC LIBRARY button,
press the PLAY/STOP button
.....and try to play a specific demo tune ........
After playback starts, press the tone button that
corresponds to the tune you want to play.from the list.
ALSO in the Troubleshooting section page 35 For DEMO tunes UNPLUG HEADPHONES
If it doesn't work, then you need to get a Technician to look at it.
Sep 18, 2014 | Music
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
I want to know how to set up a master on my tascam dp02
first set the in and out points of song make sure your holding down the shift key while setting in and out points.then pres shift key holding down on it pres master key it should start flashing.then pres record play.good luck
Jun 11, 2009 | Tascam Music
Machine appears to record per instruction manual but will not play anything back and the instruction manual includes NOTHING on playback except to hit STOP when we're through recording, back up to the...
it appears to be recording but is it really?
when you are recording there are two levels you should see moving up and down on the screen. the input volume and the recording volume per track. dont forget to arm the track. tascam has a silly way to arm the track on some of there unit. its combination of buttons. something like hold down the record button and press the track arm button then release both. when youre ready to record press play.
Feb 22, 2009 | Tascam DP01 All-In-One Recording Package...
Poor Recording Level on the Tascam DP-02CF
When I record on DP-02/CF Tascam I can't get the music to play back. Do I have to do something other than rewind to be able to hear it? Albert S.
Feb 08, 2009 | Tascam 2488 Portastudio Multitrack...
Transferring songs onto new CF card
You'll have to create backups of your songs and transfer those backups using USB to your PC. Then with the 8 GB card inserted you can reimport them to the Tascam (USB) and restore them to the current working song which will then get saved on your 8 GB card. Do this for each song and then you can discard (delete) those backed up song files while connected to the PC.
Hope this helps.
bd.
Feb 07, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam DP-02 cd player...
You cannot rip a CD directly into the DP-02 using the unit's CD drive.
Your choices for doing what you want are:
1.) Rip the CD into .wav files onto your PC using ripper of your choice. Then you'll have to edit the resulting .wav file using a program like 'Audacity' (which is a free one) and convert the stereo wav files into 2 mono wav files. You'll have to save the mono files with dos 8.3 filenames and then import them into the DP02 using the instructions for importing wav files in the manual. To preserve the stereo, import each mono wav file to a separate adjacent track on the DP02 and then pan one left and one right.
2.) You could play the CD on a stereo and connect the stereo outs to the two inputs on the DP02 to record the CD track. You'll need patch cords which are RCA (mini phono 1/8" jack) to regular phono (1/4") to do this.
Cheers,
bd.
Nov 09, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam dp02
Jul 20, 2008 | Audio Players & Recorders
93 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
