Question about Sony VAIO VGN-NR385E Laptop
Left mouse button of Sony VGN-NR38M (nt touch pad) is not working often, and some times need to press hard, please help
Posted by a1ali_36 on
Michael C. De Vito
    Genius:
  • 1,970 Answers
Mcdevito75 here, Bring laptop to Staples, Best buy for testing, sounds like that key could be hanging up. maybe some sort of oil needed.
Posted on Jun 26, 2010
I would like to disable the touch pad and use an external mouse. Sony Vaio VGN A190
Please follow the steps to disable the Touchpad under XP environment:
First, click the Start button, then click VAIO Support Central .
In the VAIO Support Central window, in the left pane , click System Maintenance .
In the right pane , click VAIO Central .
In the VAIO Central window, click the System Information tab.
On the System Information tab, click the Plus symbol next to Keyboard and Mouse .
Under Keyboard and Mouse , double-click Built-in Pointing Device .
In the Built-in Pointing Device window, click to clear the Enable box.
Click the OK button.
In the Built-in Pointing Device dialog box, click the Yes button.
Thanks!!!!
Dec 24, 2010 | Sony VGN-A190 Notebook
The left button of Mousepad(one on laptop, but not touch pad) is often not working and sometimes need to press hard. Model VGN-NR38M, Sony Vaio. please help
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .
Jun 26, 2010 | Sony VAIO VGN-NR385E Laptop
PC's mouse is not functioning properly
http://www.sony.com/index.php
go to services and support and download the mouse drivers
May 12, 2010 | Sony VAIO VGN-NR385E Laptop
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
My Mouse track pad is pushing the mouse into the upper right corner of the screen. Do I need a new thumbpad? Is this an easy fix? Should I send it in?
Hi there, please open your touchpad settings and set the touch pad thumb pressing sense location. Make it center of touch pad & save the settings. Total sensible location is 5. 4 corner & 1 center. Just fixed center. Its will work proper. If not then go for new one.
Thanks & waiting for your feedback.
Feb 09, 2010 | Sony VAIO VGN-UX280P Notebook
My laptop left mouse button has stopped working
Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
WildeFalcon
Feb 06, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
The left mouse button on my laptop isn't working right. I have to press down really hard and the touch screen doesn't move the cursor when I run my finger over it (Sony Vaio VGN-NR SERIES)
Go To Start-> Settings-> Control Panel-> Mouse - Check All Options Are As U Wish Then Try Unplugging It Restart Pc It Should Work...
Nov 21, 2009 | Computers & Internet
Can't move the dialog box with the mouse using the touch pad can't move an open window or grab the end of the window to resize the window
there are two ways to do that using the touch pad. first is by tapping it twice while the mouse pointer is pointed at the ends or at the dialog box and then dragging it to anywhere you want. second way is to use the left clicker of your touch pad by pressing and holding it while the pointer is pointed at the dialog box and then use the touch pad to drag it to anywhere you want.... i hope this helps...
Nov 10, 2009 | Sony Vaio VGN-NR110E/S Notebook
Malfunction of the left button of the touch pad
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .Hey it's a Cheap laptop and uses cheap parts.
Jan 08, 2009 | Sony VAIO VGN-SZ330P/B Notebook
Touch pad not working
If Windows service pack 1 - doesnot all recent drivers and will not recognize your touch pad and even keyboard.
Try to boot on Safemode.
Just press on F8 when your start your computer - and connect an usb mouse and try to install the touch pad drive manually.
Then boot on normal mode and install your other drivers..
It is recommended to update quickly your os to Service pack 2 or 3 for best performance of your computer.
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Sony VAIO VGN-NR385E Laptop Logo
513 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
