An expert that got 20 achievements.
An expert that got 10 achievements.
An expert that got 5 achievements.
Sony Master
Re:
Sure you can get it done at the nearest electronic service centre unless you wantt it to be done at the authorised service centre. But if you can be confident check your bateries, check your belts within the set and replace them with the correct size. It is possible to get this done if you can do it patiently and maybe a helping hand. Good luck Good day
To play a video podcast, your Walkman must have video capabilities. If
you subscribe via RSS, Sony's Media Manager for Walkman software will
manage podcast downloads to the Walkman.
when i try to play the music on my mp3 player ( sony walkman ) it says cannot play please connect to compliant software and update license info. i'm not sure how to do this
Please check for the belts if the battery you have installed is new and the set gives a hum on play. If not you will have to check the power switch, the mechanism switch and the line to the main board.
If the motor turns but not the capstan and the reel then change the belt, the rollers or the pulley. I hope this will get your set back to action. Good day
Sony Walkman will accept converted video file and it's format should be MPG-4 or MP4. other format will no be played and be sure you have to put that in your "Video" folder of your Walkman.
I think ur MP4 file is in wrong resolution for sony walkman, you could try this Daniusoft video covnerter, It is already optimized for output setting for sony walkman ... easy-to-use.
