SOURCE: Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Thanks
Nikunj Pattni
[email protected]
SOURCE: Baby Monitor False Alarm Problem
You can try adjusting the sensitivity on back of the nursery unit. But the most major thing I found was to ensure the sensor pad was on a firm surface. I used a large piece of cardboard from a flattened box. Angel Care recommends plywood or similar but the cardboard worked perfect for me. Put the sensor on top of the cardboard and then the mattress on top of that. The sensor should also be placed according to directions (under child approx center of mattress).
SOURCE: I need a parent unit for Angelcare AC401 - mine
I found a website called www.angelcare-uk.co.uk and there was the answer! Works brilliantly now. It was just the parent unit and nursery unit needed to reconnect with each other.
SOURCE: AngelCare Baby monitor and movement sensor AC401 mike problems.
Press Menu, then press Menu two more times until the icon on the far top left of the little display shows up, then you'll see the on/off option if you use the arrow keys. Use the arrow to select OFF and then press Select. Then press Exit.
