Hi. I did some reasearch on your TV, and this is what I found with regards to updating th software on the TV.
Firstly, you will need to download the “autorun.upg” file, and copy it to the root directory of a USB portable memory device. You can download the file at the following link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&sct=PLASMA_TV_SU&cat=TV_CA&session=20100625163836_170.65.128.6&grp=SOUND_AND_VISION_GR&ctn=50PFP5332D/37&mid=Link_Software&hlt=Link_Software
1- Power off your TV and remove all memory devices.
2- Insert the USB portable memory that contains the downloaded software upgrade.
3- Switch on your TV with the power switch on the side of the TV.
4- At startup the TV will scan the USB portable memory until it finds the
update content. The TV will automatically go to the upgrade mode. After a few seconds it will display the status of the upgrade procedure.
Note: Do not remove the USB drive from the TV while it is updrading.
Hope this helps :)
Hi
Thanks for using FixYa. 6 blinks in your plasma TV
means that the issue is with the power supply board. To start with you’ll have
to open the back of the unit and then check the power supply board for any bad components;
usually the capacitors go bad/bulged and cause these kinds of issues. You’ll
need to replace the components with the exact same ones and/or replace the
board completely to avoid any future issues. Please do accept the solution if the issue is
resolved or else revert for further assistance.
Thanks
Rylee
replaced with new boards ( not much help from service tecs in my area)
thanks
