Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Further investigation revealed that the receivers TV1 input tuner has failed. I went to the dish point screen. TV2 input tuner worked fine with both satellites. TV1 input tuner was dead. I switched the input cables and got the same results. Therefore the LNB and cables are OK, TV1 tuner failed. Replacement receiver is on the way for $15.
Further investigation revealed that the receivers TV1 input tuner failed. I went to the dish point screen: TV2 input tuner worked fine with both satellites, TV1 input tuner was dead. I switched the input cables and got the same results. Therefore the LNB and cables are OK, TV1 tuner failed. A replacement receiver is on the way for $15.
