NO GOAL stated, at all, (like I want to connect PC to TV)?????
hp p6213w (came new vista or w7)
what is it? what does it do?
I see its off the sale shelf, means nobody wants them...
never buy from that shelf until you find it
1: still supported,
2: if yes, what OS it does support first.
or you will fail.
does not work, what are the symptoms.
monitor shows.
no signal , no sync , out of range errors?
the monitor will show errors !
do learn that the VGA has no sound ! does NOT.
so this is just passive video converter (hdmi to VGA video)
no sound unless you connect your sound port on rear of PC to amplified speakers.
if I stare at you photo for long time
I think it says HDMI (adaptor?) I zoomed it with special tools.
HDMI to VGA
so go to ebay and buy one, that works on YOUR OS.
or bestbuy off the self.
one for sale at amazon shows this. no reviews, no spec.
does your PC have HDMI port? only and you want to
run VGA 15pin monitor? using this.
this does not work backwards, PC VGA to HDMI. if that is your goal and btw, unstated goa.
ONA17AV004
DID YOU TYPE THE MODEL NUMBER WRONG?
I see this at walfart.
https://www.walmart.com/ip/Onn-HDMI-To-VGA-Adapter-Connector/452148202
now some issues.
This PC came with no HDMI port. at all. just VGA
why not just use your onboard, VGA to VGA monitor?
this PC you can in fact buy an HDMI video card and plug it in to the PCI-express slot and run faster VGA and full HDMI
to a TV or to any Monitor.
the device above if or laptops only, that have no VGA jack.
or any device lacking VGA< with HDMI port.
it does NOT convert backwards VGA to HDMI say for PC to TV.
that is what it does and can not do.
better is tell what want to do
the ask how, and we can point to low cost choices
