No picutre just black-loud pop when I turned it on
Samsung 37 in 2 1/2 years old
TV was working fine In the morning turned on heard a pop with no picture. turned off turned back on TV red light on but screen is black
Issue is either with the X or Y sustain board. Look for a cap that has blown or a cracked solid state device on the board. One of them is responsible for the ***** croak you heard.
It sounds like your TV lamp popped this lamps are rated for 6000-8000 life hours witch is a average time of 2-4 years take the lamp out I'm sure you will see broken glass inside the lamp I found the lamp you need
you have blown an internal fuse you might be suprized to learn that ther is someone veryclose to you who might be able to fix it a lot of people who fix tv's work from home bassically you just neeed ot repalce a small circut board inside it
just google and try to find them
take tc back it should sill be under warenty if they refuse you can say t othem this is not fit for its purpose and force them to fix or replace it
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
It needs a small signal board, it is still under warinty, up 1 year after you but it, look in your manuel, or on line for there phone number call them, asap, they should set you up with a service center, and they will cover part and labor
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
Possible problems:
* The TV set may be unplugged.
* A fuse or circuit breaker may be blown or switched off.
* The remote control unit (RCU) may be disabled.
Solutions:
* Make sure the TV/VCR are plugged in and the wall switch is on.
* Check the fuse or circuit breaker. Test the outlet with a lamp.
* Replace the RCU's batteries: if this fails exchange the unit.
