Trying to install a new sd memory card, screen says it needs formatting click continue and says formatting will delete everything on memory care click continue shows it is formatting then says memory card requires formatting, it just keeps going aroung in circles. What do I do?
It is obvious to me that the player can't read the video off an SD drive. In my experience that card slot is for installing updated firmware not video material.
click start click on my computer you should see your 2 gb drive right click then select format another way is to control panel administrive tools computer management disk management right click on your 2 gb drive select format hope this helps
I'm suspecting that you are trying to use a new 4GB or larger SDHC card with your older model camera. Please note that your model camera can only use 2GB or less standard SD cards (and NOT SDHC). 2GB SD cards are inexpensive, and still available on Amazon.com if your local store no longer carries them.
Step One: Tosavedata, useEASEUSData Recoverysoftware(freeversion-1GBof datarecovery).how: 1.Download and installEASEUSData Recovery 2.ChooseCompleteRecovery-Next 3.Choosethe drivemicro SD-Next 4.Save thedatato the harddisk(max.1GB) 5.Because ofyourmicro SD2GB,repeatthe process ofrecovery(repeatstep 2, 3,4) Afterall data issecure, do theprocess of removingthe micro SDpassword
Step Two: The first alternative- use thesoftwareHPDriveKeyBootUtility 1.Downloadand install thesoftwareHPDriveKeyBootUtility 2.Then, doubleclick the filecp006049.exe 3.Ifyou are usingWinXP,double clickthe filecp006049.exe-select Install. 4.Ifyou are usingWinVistaorSeven,double clickthe filecp006049.exe- selectextrack. 5.Then, open the program"HPDriveKeyBootUtility orhpdkbu.exe"-Next-selectdrive-Next-Create neworreplaceexitingconfiguration -Next-Harddrive-Next-Create newfile system -Next-waituntil theprocessis completed-Next-Finish. 6.Remove themicro SDfrom the USB port,theninsert it again. 7.Quickformatmicro SD(FAT file system) 8.Restoreall data,to themicro SD.
The second alternative- usesoftwareHDDLow LevelFormat Tool 1.Download and installHDDLow LevelFormat Tool 2.Selectmicro SD-Continue 3.ClickS.M.A.R.T-clickGet SmartAttributes 4.ClickLOWLEVELFORMAT-clickFormatthis device 5.Waituntilthe processis complete- pressOK 6.Remove themicro SDfrom the USB port,theninsert it again. 7.Quickformatmicro SD(FAT file system) 8.Restoreall data,to themicro SD.
I hopethisinformationhelps.Thank you forusingFixYa!
