I use MGI photosuite and love it. I just bought a new computer with Windows 7 and MGI photosuite will not load. Is there a MGI photosuite that will work on Windows 7?
Windows 7 and 8 much the same (32 and 64 bit) you may missing files for Internet Explorer.
Just today I was able to get PhotoSuite 4 to work in Windows 8. PhotoSuite 4 (P.S. 4) is dependent upon Internet Explorer 5 (I.E. 5) browser for its content/software to work. The original P.S. 4 CD has
I.E. 5 installer, I tried to install and the install quit with a check box to force install of all components. Internet Explorer 10 for Windows 8 was not affected in any way, that's how I got back here anyway.
I have read ton's of suggestions and one mentioned I.E. Browser dependency and walla it was the answer that took me ten minutes to get it up and running.
SOURCE: Running MGI Photosuite version 8.05 in Vista
MGI Photosuite on Vista, THE FINAL SOLUTION!!! First you need to get hold of an MGI disc or a download. I have been trying to get MGI Photosuite III SE to install on Vista for months without success and then when I thought I'd finally sorted it I could not launch the program due to a script error. You do not need Virtual PC, Virtual XP or any add-ons. Simply find and right click the the MGI setup file, check the run in compatibility mode as Windows XP SP2 and install. After install, send a program launch shortcut to your desktop, right click, go to properties and check the Windows XP compatibility mode once again. Finally, while you still have the compatibility screen open add a tick check to Run As Administrator. Hey presto my beloved MGI Photosuite is back! MGI is fantastic for being user friendly and simple, and although I know other users insist there are better programs, I’ve tried loads and I still think it’s a winner.
SOURCE: Will mgi photosuite 8.1 work with windows 7
You may try installing it in windows 7 and check. If you are unable to install
it then I suggest you to install it in windows XP compatibility mode and check.
First create a restore point before trying this step.
SOURCE: mgi photosuite version 4.0 and
I am by no means a computer expert. somehow I got my mgi to download, by going in and changing what read the cd. I did not install using windows media. somehow I overrode that. BUT...even tho it is installed and working...I get error messages for certain functions. You can hit "continue" 4 times and then it works. Someone told me this would hurt my computer. Any insight?????
SOURCE: What replaces MGI Photosuite for Windows 7?
I had no luck with Photosuite 4 on Windows 7, even with backwards compatibility, vista or XP, but Photosuite 8.06 loaded up and appears to work okay, it is older but does seem to work on windows 7.
