Sanyo DP32746 32 in. LCD Television Logo
Posted on Jun 25, 2010
I have a tv that is a few months old. when I try to turn on blue light comes on but nothing else. Have unplugged, checked remote and used manual buttons...Help
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Jun 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
629
Points
When this happened to me, I unplugged and waited 10 seconds and then replugged...it worked. Hope this helps.
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
Safe/dynamic mode appears on the screen for half a second
You have a power supply problem.Most brand they have modules.
If you can open the back you will see a few separated Modules.You
will see a power supply module just replace it Take note of the connectorsThey have letters usualy to match the plugs.
By the away do you have any sound?
3answers
Turn on tv blue light comes on.screen stays dark .nothing happens .tv would come on after 10 minutes thenit started taking longer. now not at all.
Well first of all you can tell us the Brand and the Model number of your TV? and tell how old is your TV?
Anyway you can try to reset your TV first unplug (switch off) your TV for 24 hours and then turn it again........... let us know if further you have the same problem.......
Good Luck!!
Thanks
Power Light on constantly ....no pic or sound....nothing.
Yep, your mainboard is damaged.
Replace it and your tv will work again
2answers
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
2helpful
Insignia NS-32LCD will not turn on.
WIth the set only 7 months old, it should still be under warranty. The problem now is that by opening it up, you effectively have voided the warranty. That being said, the problem is that a problem has been detected internally and the set shuts down to prevent further damage. The first suspect is the main power supply board. I would try for warranty service first. If that is not available a local service shop should be able to take some measurements inside to detemine whether the power supply is not working correctly or if the suply is being told to shutdown. WIth what little info is available here and not being able to examine the actual unit, remote diagnosis will be difficult.
Keep us posted.
Dan
Acoustic solutions TV
There is not a RF TV signal or the RF circuit is has a bad funtion, try to verify de antenna connection
3helpful
3answers
Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
