Computers & Internet Logo
Question about Mathsoft Solving and Optimization Extension Pack III (46513) for PC
What is base 6 of 486
Posted by babyjoy_me16 on
Anonymous
    Sniper:
  • 146 Answers
For converting 486 to the base 10 to base 6 dived 486 by 6 and note the quotients and remainder.
486/6 = quotient = 81 remainder = 0.now divide quotient by 6 and note quotient and remainder.
81/6 = quotient 13 remainder= 3
13/6 = quotient 2 remainder = 1 .
2/6 = quotient 0 remainder= 2.
Hence reading remainder from below we get 2130.
So 486 tot he base 10 is equivalent to 2130 to the base 6.
Thank you.
Posted on Jun 26, 2010
I have d3098. The cordless is saying power problem with base phone. My cleaning lady threw out my manual and Idon't even know where battery is I need a new manual.
I suspect remote is unable to communicate with the base and is reporting the issue as power loss at base.
So does the base function, makes and receives calls?
Reset the base unit and power supply by unplugging the base power supply from the wall, wait at least 1 minute, plug base power supply back into wall outlet.
Reset remote by removing battery wait a minute, reinstall battery.
If after the reset the base can't make/receive calls, its likely failed.
If the base works and the remote still reports base power issue, could be either base or remote.
The manual is at the following link...
http://www.uniden.info/download/index.cfm?s=D3098
tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
How to remove turn base from base on a Makita LS1011 Slide Compound Saw?
If you have removed the kerf boards and the center bolt the saw will lift straight off the turn base. It is possible the aluminum is deformed a little, but it will pull straight up and off if that bolt is out
Nov 27, 2014 • Makita Saws
Tring to add a handset to a att 5840 base!
The process is called "Registering."
From another fixya post:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
How do iworkout how to convert base 10 numbers to binary
Press MODE 4 to switch to the BASE-N mode. Enter the base-10 number and press =. Press SHIFT [BIN] (the LOG key) to switch to base-2 and see the result.
In general, once in the BASE-N mode, to convert a number from one base to another, switch the calculator into the first base using the keys in the third row, enter the number, press =, then switch the calculator into the second base.
Press MODE 1 (or 2) to exit the BASE-N mode.
2answers
Uniden dect 1580. I have 2 bases and they are both identified as base #1. How do I change one of them to base 2?
I too have a Uniden Dect6 Model 1580-2 with two handsets. The system comes with 1 base (the larger one) and a phone charger (the smaller one with no buttons, just the charger cradle and a led that lights when phone is plugged in).
I was puzzled with your 2 bases affirmation and I checked with my set.
I took handset 1 and pressed the Menu button. I selected HANDSET SETUP. The first option under this heading is Select base, with two choices Auto and Base #1. I tried both choices and each time there was only a base #1, no base #2, thus confirming that in the set there was only one base.
If you have more than two bases, one handset can be registered to more than one base (actually 4 compatible bases). I suspect that you have to register each handset to each base. By doing so, each handset will know that it can connect to two bases and you will be able to select base#1 and base#2.
I need the base id for a vtech house phone model number 6772
It sounds like you are trying to register the handset(s) to the base. Once the handset is charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit press MENU, scroll down to Display Base ID, press OK, and the Base ID code will display. If NEW appears in your handset display, press the soft key under it and enter the base ID code you found in the base display. If 'New' does not appear on your handset, press MENU and then scroll down to REGISTER. Press OK and then enter the base ID code. If the handset is already registered, please deregister all then register again. To deregister a handset which is registered to the base model 20-2431, Using the soft keys on the base, press the 'MENU', then press the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted. Press 'SET' . If your handset is registered to the base model 20-2481, Using the soft keys on the base, press the 'MENU', then press the down arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
How do I get 2 Uniden TRU8885 base to operate as one base?
NO ONLY DECT 6.0 MODELS ARE ABLE TO DO THAT, NOT YOUR MODEL.
1helpful
2answers
Internet explorer raised unhandled exception in third party module IE will not start and the below call stack pops up every time. BASE:16940000,001B:1699D18C WINUTIL5.DLL,...
hi there,
it seems u got a big problem with ie7,
this is what is get right : Internet Explorer Unhandled Exception
> Internet Explorer raised unhandled exception in third party module and
> should be closed. We are sorry for inconvinience.
> Extended Exception Information
> Module: urlmon.dll
> Version Info: UNICODE; v.4, 0, 2, 3
> Call Stack:
> BASE:7E1E0000,001B:7E21B5CE urlmon.dll
> BASE:7E1E0000,001B:7E1F3FD9 urlmon.dll
> BASE:7E1E0000,001B:7E2150F2 urlmon.dll
> BASE:7E1E0000,001B:7E203342 urlmon.dll
> BASE:7E1E0000,001B:7E1FCD5C urlmon.dll
> BASE:7E1E0000,001B:7E1FCD32 urlmon.dll
> BASE:7E1E0000,001B:7E1FCB8C urlmon.dll
> BASE:7E1E0000,001B:7E1FCB69 urlmon.dll
> BASE:7DC30000,001B:7DE84E02 mshtml.dll
> BASE:7DC30000,001B:7DD69D68 mshtml.dll
> Restart Internet Explorer Close
there is a simple solution for that just follow these steps and than all will go good
I would recommend resetting it to it's default state. This usually takes care of any problematic plug-ins. below has details on how to do this.
1. Click the Tools menu, and then select 'Internet Options.
2. Next, click on the Advanced tab to the far right and click Reset.
3. Another dialog box will then open up, click Reset.
4. Once IE7 is done restoring to the default settings, click Close and then OK.
5. Close any browsers you may have had open and restart it. Everything should now be reset to the default.
or for just click this link and than click on download and run ie7 new
Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Top Mathsoft Computers & Internet Experts
 Grubhead
Grubhead
Kolbrun...
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
