Question about Carrier 38CKC030 Air Conditioner
Not blowing cold air
My air conditioner is not blowing cold air but the fan is still working outside. The capacitor was replaced last year. No other servicing has been done to it for the last 8 years.
Posted by mmartin2505 on
D. Floyd Kolb
  • Carrier Master
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioningNot blowing cold air - 2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jun 25, 2010
I am working air condistiner but continue e 45 no fan working no a.c. working please help me
Could you explain more what is the problem. When outside fan is not working and not blowing cold air usually ( hopefully ) the capacitor is at fault ( if u hear compressor trying to start then stop then try to replace capacitor - silver round thingy in outside unit )
Jul 15, 2016 | Heating & Cooling
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
Airconditioner blowing not cold
Yes. its the run capacitor that is bad. as far as the filter, evaporator and condenser coil is clean and compressor is okay as you said. get the exact type and model of the capacitor and replace... let me know... all the best.
Jan 30, 2014 | Panasonic Heating & Cooling
I just replaced the fan and the capastitor on an outside air conditioner unit yesterday. Today it was blowing so cold I increased the temp. on the thermostat. Now it is blowing 77 degrees air instead of...
The air being blown at the condensing unit isn't the air that blows inside. I seriously doubt what you said about it getting so cold. I believe that the wires to the capacitor were improperly installed, and your compressor isn't operating. Don't confuse the outdoor fan operation with compressor operation (they both share the same contactor as a switch). On the capacitor, the brown wire connects to fan, compressor attaches to "HERM" common attaches to the contactor. I didn't mention the colors of the common or compressor wires because they differ among manufacturers.
Aug 27, 2013 | Goldstar R1003 Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
Wall A/C only SPORADICALLY blowing cold air. Turn it off and back on, you can feel it's cold, but only if you're 5 inches from it. After a couple of minutes, fan is only blowing warm air again. Vacuumed...
if it blows be not with force like it used to it can be fan motor capacitor not boosting fan speed. but if speed is not the issuse. remove and clean both coils water hose
Aug 29, 2009 | Heating & Cooling
Not blowing cold air. Checked outside unit and looks clean but fan not turning
You may have a bad capacitor, fan relay/contactor, or motor. Check the capacitor for the fan, if the capacitor is ok, then check the fan relay/contactor. If this is ok, then the fan motor is bad.
Aug 02, 2009 | Goodman CKL36AR36 Air Conditioner
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Carrier 38CKC030 Air Conditioner Logo
482 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
