The air conditioner is cooling but it does not seem to be cycling correctly. The air conditioner runs constantly when the temperature is over 85 degrees outside.
Posted by therdman on
D. Floyd Kolb
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioning trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jun 25, 2010
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Constant cycling
do you use a inverter.. or any protection circuit>
if so remove it and connect it directly
Apr 05, 2008 | Dometic Rooftop RV Air Conditioner
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
My panasonic air conditioner does not turn off when cooling
At what temperature is the thermostat?
The temperature should never be lower than 70?F (21?C) for the unit to operate properly. If your temperature setting is above 70?F, then your unit might have a problem with the temperature sensor that controls the "on/off" cycle on your unit. For that you will need a professional certified HVAC tech to inspect it.
Most people think that lowering the temperature to the minimum will cool the room faster, but that is not the case. Since HVAC units move the air at a specific rate, it can only transfer the temperature, thus cooling/heating the air, within those parameters. That's what the calculation for the BTU is for. Normally cooling/heating the room to the desired temperature should take about 1 hour, but some new inverter units can do it in only 30 minutes or so. Lowering the temperature constantly or even keeping it at the lowest setting may cause premature failure of the unit.
Aug 04, 2014 | Panasonic 36PEF1U6 31,200 BTU Single Zone...
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
What does the temperature control slide do, it runs from 64 - 85, if it is lower (64 )does that mean the unit cools more
The lower the number means the temperature of air coming out from that aircon would be cooler,
May 11, 2011 | Quasar Heating & Cooling
How can I determine if the ac is removing the correct amount of moisture from the air?
tech answer is:3 pints of water per hour per 1 ton of cooling.
General rule of thumb is 20-25% of the capacity of the unit is devoted to dehumidifying.
If unit runs constantly and the temp really does not seem to be effected, unit is probably too small. If unit runs and cycles off frequently, i.e. short run times, and humidity is high, unit is too big.
Hope this helps
Jun 25, 2009 | Heating & Cooling
My A/C (Carrier weathermaker 8000 hybrid) is not cooling properly
set the t-stat low and let it run for 5 minutes , stick a thermometer in the return air closest to the unit as possible until you get a good reading , then stick the thermometer in the cold air supply again closest to the indoor unit as possible let sit until it stops going down in temp.
this is called your temp difference and it should be atleast a 14deg. F difference from in to out. if its lower you have a refrigerant problem, Let me know how it goes.
Phil
Jun 10, 2009 | Heating & Cooling
Runs constantly no matter what the room temperature is
too cold - thermostat controls in error
Not getting cool? = low freon, dirty condensers, dirty evaporators, moisture in freon
May 04, 2009 | Heating & Cooling
Remington PTAC Heater/Cooler
you may have a bad heat sequencer
Jan 11, 2009 | Heating & Cooling
Heating & Cooling Logo
546 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
