Right under the resting place of the cassettes. However just emptying will not fix it you need to find the reset software for your model
It covers the whole of the bottom. Remove it carefully noting how it fitted. Make a solution of teaspoon of bleach to 1 cup water dunk in a few times to remove ink. Pat dry and finish carefully with a hair dryer on medium. Then replace and follow these instructions
Canon MP780 Waste Ink
FULL Reset (Should work with
MP700/730/750)
This reset should be used once waste ink
counter reaches full and
lock-out occurs.
- To select something... Use the '-' and '+' buttons and then
the
"OK" button.
- To go back... Use the "Stop/Reset" button
- To reset... Use the "On/Off" button (only after you've gone
back as far as possible it seems)
Reboot and enjoy
please rate my help++++Thanks for using FIXYA
SOURCE: Waste Ink in a Printer
u will have to lose the printer then bring out ink waste bin and then flush it manually n insert it back.
SOURCE: Canon printer i 475D
This may be worth a try
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
SOURCE: Cannon printer MultiPass.MP390 waste ink
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select
#8 Printer Test, it will do something here like cleaning or something
then it will come up with some other option this is where it gets a bit
confusing cause now all it says is like 8-2 or 8-3 push the + or -
button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
SOURCE: Waste ink near full
Here is a link that provides info about this problem. hope this helps.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=10443#SupportDetailAct
SOURCE: The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
