Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD-52525 will not turn on, Flashing Red light.
This is the same problem I had last Year! it was down a while for a New
Chassis Assy.. Is this an ongoing issue ?
Posted by jjritter36 on
Anonymous
  • 35 Answers
If that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Posted on Jun 25, 2010
Flashing lamp light on mitsubishi 52525
The lamp cover is not installed properly or the lamp door switch isnt working thats what causes the 32 error.
Apr 08, 2013 | Mitsubishi WD-52525 52" Rear Projection...
4 year old Mitsubishi wd 52528 has had flashing timer light then turns itself off since power outage. After turns itself off, can't get it back on, even with reset.
Need to unplug for computer to power down then plug back in, light will blink for a few then go out and you should be able to power on!
Feb 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No picture or sound
did you remove any covers,lamp or filter? unplug for a few and try again!
Jan 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525
This chassis has bad capacitors on the PWB,FMt, DM and the other boards that need to be replaced. They are all jamicon capacitors 1000uf and larger there are roughly 10 in the set that need to be replaced. Let me know if you need further instructions on this model.
Apr 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV Shuts down
convergence amp IC's i would start with.
Dec 03, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Shuts off, shows red lamp light even after replacing lamp
Turn on the set and let it shut down. push in the Menu and Device (or input, I don't have a schematic in front of me) buttons on the front of the set at the same time and hold until the green light starts flashing. Then release. There will be two different sets of flashes, such as, 3 and 6. The code 12 means the set is opperating fine. The other codes will tell you what part of the set needs repaired. Also, remove the bulb and check the ballast connection to the bulb. I find the connection for the bulb bent over when a customer replaces the lamp sometimes. Let me know what you find and we can go from there.
Feb 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
159 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
