Haier HEATER CPN10XH9 Air Conditioner Logo
Posted on Jun 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a haier portable airconditioner CPN10XH9,that was purchased about a year ago, when i turned it on this year it was runing fine, but it has started to leak water. I opened the drain plug and drained the water but it will only run for a little while and it starts to leak water again, i need help
Anonymous
Level 3:
Genius:
  • Master 1,970 Answers
  • Posted on Jun 25, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1970
Questions
0
Helped
846787
Points
4702
Mcdevito75 here, You may have to use your warantee to fix a p[ossible leak in your unit. Check with your local A/C repair shop for advise.
1helpful
3answers
Hi, I just purchased this used. It was working fine for one day, but now it won't turn on. Can u help? Haier CPN12XH9 12000 BTU Portable Air
If the water collection tank is full, it will not turn ON. Since you said the unit worked fine for one day and now it won't turn ON, more than likely, that's the problem. After draining the tank, the unit should reset itself and turn ON like it should.
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan or bowl that's capable of holding up yo a quart of water. O r roll the unit to a floor drain or outside to drain it. If you choose to drain it into a pan, turn the unit OFF & unplug it, before draining it.
I hope this helped you and thanks for choosing FixYa
I have a HD456E that I purchased at Menards about 2 years ago. It's worked fine until a few days ago. It is running but, not a drop of water is in the pan. What do I need to do? I have misplaced my...
Hello friend, I may be of help after all in locating a user/service manual for your hair HD456E dehumidifier.
Check the link below and download the specific manual.
Hope this helps https://haier.encompass.com/shop/model_research_docs/?file=/HAI/om/HD656E.pdf
Even though you'd notice the link reads at the end hd656e.PDF, go ahead and download it. Same manual applies. *smiles*
It is specified on the user manual HD456E
2helpful
Air Conditioner/Heater not working for more than 2 hours.
If you are running it in a very humid envioronment then it will make more water than it can evaporate off.
HAIER 1 YR. OLD A/C UNIT BLOWS ONLY WARM AIR
well it sounds like the compressor is not turning on. does it have thermostat? if so turn it way down. clean any filters. is it a window unite or portable most of them are too costly to repair unless you do it your self.
1helpful
Haier window airconditioner cooling is not effective
there is a temperature sensor bulb in front of the evaporator. check if it is too near to the coil. move iit away about an inch.
2helpful
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
E1 code airconditioner not working
Hi Baygirl, you didn't say what model you have, but you can normally find the codes explained on the manufacturers web site. UYou shoulda bought 1 with a remote though - I hate getting off the sofa
1helpful
Pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
