Question about Panasonic Viera TH-50PZ85U Plasma TV
10 red blinking lights on my Panasonic Plasma TV, will pause for few seconds, then blinks again. TV will not power on.
Posted by johnpoy7 on
Anonymous
    Sniper:
  • 72 Answers
This is a power supply issue - found a company that has used power supplies, they sell them for $60.00. We recommend a professional install the board because the voltage needs to be adjusted after the install or you could damage something else. The high voltage in the set can KILL you soe be very careful. The web address for the PS board is plasmafix.com.
Posted on Jul 03, 2010
Anonymous
I had a similar problem this morning switching the TV back and forth between a Wii game and the Directv connection. I had the dreaded 2 blinks and later 10 blinks. If I held down the power button, it would eventually stop but if I tried to power up the TV, the blinking resumed. I unplugged the TV for short periods and then tried it again to no avail. I finally gave up and called Best Buy and was told to call the corporate number to get repair scheduled. I was busy at the time so I just unplugged the TV and left it unplugged for about 4 hours. Later, I plugged it in again and this time it worked. I read somewhere on the web that turning the TV off and on over short periods will cause some of these problems. You may have a bad board but you could try unplugging and waiting several hours before trying it again.
Posted on Jun 26, 2010
  • Anonymous Jun 26, 2010
    No additional information.
  • hsgunbunny Sep 19, 2010
    i have a panasonic tc p4s2s 50in lcd that started dong this after three days!!!
chrisbilquis
    New Friend:
I had this same problem. I was told that it was problem with the voltage coming from the HDMI cable. I unplugged all my HDMI cables and the power cord to the tv and waited a couple minutes. It turned on fine after that. I narrowed the problem down to my xbox 360. If the xbox is turned on before the TV then i get the same problem. I have learned to turn my TV on first then my xbox 360 after and have not had a problem since. Hope this helps. Good luck!
Posted on Jan 08, 2013
  • raymichaelad
    raymichaelad Feb 02, 2013
    Funny, I just started having that same issue. Ended up with the same result. When I first got my 360 I had it set to 720p (my TV res.) but changed it to auto sometime ago and then the problems started happening, don't know it it's related though.
  • Sp Gupta Feb 16, 2015
    Interesting.
Watson
    New Friend:
  • 45 Answers
10 blinks indicates a problem with either the P, A, SC or SS boards - you need to do a systems diagnosis to determine the bad board. The P, SC and SS boards require a voltage adjustment, which may require an oscilliscope. There are high voltages involved (even when power is disconnected), so considerable caution is advised.
Posted on Jul 12, 2010
Chi Chu
  • Panasonic Master
  • 8,457 Answers
The power supply board is dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jun 24, 2010
John Reilly
  • 37 Answers
I had the same problem with my TH-PZ80U and I turned off the power on my power strip (unplugged the TV), waited a few seconds and pluggeed in the TV again. It worked.
Posted on Nov 25, 2010
Who to fix broken panasonic plasma tv
Adam, 1 st thing to try is holding the power button in 20 seconds and see if it resets.Check the links below and do not be afraid to google search your problem yourself, there is a lot of info. out there onm this problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Panasonic Plasma TV Repair Understanding 10 Blink Code for 2011 Panasonic...
Panasonic 10 flashing red light
Panasonic Plasma 10 and 2 Blinks TEA1611 ETX2MM702 704 706 Power Supply TH...
May 02, 2016 | Panasonic TCP65VT25 65 inch VT25 1080p...
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I have a Panasonic plasma TV model# TH-42PX75U --- here is a link to Panasonic web site for this model...
Unfortunately your going to have to have it serviced by an Authorized Panasonic Dealer. Independent shops will not be authorized to order parts without the consent of Panasonic. They are rough to deal with.
Dec 20, 2010 | Televison & Video
Oven will not bake but everything else works fine
What is the red light blinking? Count the blinks before it pauses and post back here. It'll give me and everyone else a starting point.
Jan 21, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Jan 04, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic Viera TH-50PZ85U Plasma TV Logo
9,826 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
