Several things could cause the problem depending on the model. First, the defrost heater could be bad. It can be checked with a continuity tester or an ohm meter. Second, the defrost timer could be bad and may not be advancing. If you manually advance the defrost timer till it is in the defrost mode, and the defrost heater does heat up, that usually indicates that the heater is good but the timer is bad. Third, there is also a defrost thermostat attached to the heater. It may be bad. The defrost thermostat is a N/C (normally closed) switch and can be checked with a continuity tester.
The heater and thermostat are in the area of the cooling coils, and the timer is many times under the refrigerator.
Hope that helps.
