Question about Samson SX1200 Amplifier
The SX 1200 supports 4 seperate speakers without problem but you must use 8ohm speakers. The manual covers this setup very clearly. Also ensure your speakers are 300W or better.
Posted on Oct 11, 2014
If I guess correct your speakers are passive. That means that they have no internal amplifier so they need to take signal from power amplifier. A way to examine that is that your speakers have no power supply input or cable (in reverse the active speakers have power supply input).
Assuming that this thought is correct you can not use your Samson SX1200 power amplifier (2 x 300 watts at 8ω and 2 x 450 watts at 4ω). You asked 2 main channels (left, right) and 2 monitor channels, so using just one stereo power amplifier is impossible for this combination. I suggest you buy 1 more stereo amplifier in order to use it for the 2 monitor channels (assuming that you use Samson for the main speakers). I don't suggest exchange Samson for one with 4 channels because in case of a problem you will have none power amplifier and you will have no sound at all. The power amplifiers also, when are using in high power levels, tends to make heat. Using 2 power amps you can manage this heat easier. I've done these thoughts assuming that all your speakers are in good condition and sound great. Otherwise we can create a new plan replacing some speakers with new ones active technology so you could avoid power amplifier channels.
These are my first thoughts about your case. I'll be glad to hear news or requests for other modifications from yours.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 24, 2010
Oct 11, 2014 | Samson SX1200 Amplifier
Jun 16, 2014 | Samson SX1200 Amplifier
Oct 12, 2012 | Samson SX1200 Amplifier
Oct 02, 2012 | Samson SX1200 Amplifier
Sep 02, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
Mar 07, 2011 | Samson SX1200 Amplifier
Jan 22, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Jan 12, 2011 | Samson SX1200 Amplifier
Jun 20, 2010 | Samson SX1200 Amplifier
May 12, 2008 | Samson SX1200 Amplifier
121 people viewed this question
