Question about HP LaserJet 4 plus Printer
ME Feed C5
When trying to print a PDF document the above message is displayed on the printer, and the document doesn't print. What does it mean?
Posted by dora349 on
DocuFlow Solutions, Inc.
    Habit-Forming:
  • 44 Answers
THE DOCUMENT WAS SAVED AS A C5 "SIZE" OF PAPER AND THE PRINTER IS ASKING YOU TO PUT THAT SIZE PAPER IN THE MANUAL FEEDER. HAVE THE PDF FILE RECREATED IF POSSIBLE AND SAVE IT AS THE APPROPRIATE SIZE PAPER.
Posted on Jun 25, 2010
How to print pdf document in lipi 6306 printer
It depends on what you mean by printing a PDF.
You can not "Direct Print" PDF documents on the 6306, you will need to pass the document through an appropriate printer driver / filter depending on the operating system used.
Simply sending a PDF document to the printer will not work
If you are using Windows simply print the PDF from Adobe Acrobat using the appropriate Windows Printer driver. If you can print a Windows Test Page, you should be able to print a PDF document- The quality of the print may not be of laser printer standard- Remember this is a Line Dot Matrix printer
Apr 03, 2013 | Tally 6312 Matrix Printer
Printer error has occurred 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 14, 2011 | Computers & Internet
Printer Error message : Printer Error has occurred. 6000
2. Open the cover.
4. Close the cover.
Dec 21, 2010 | Canon Office Equipment & Supplies
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Printer is online, but status is offline
Hi, make sure if the pdf you can't print is restricted by owner password which prevents you from copying, editing and printing pdf files. User a pdf password remover to remove pdf password. AnyBizSoft has a product like this.
Jan 15, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Our 4506 message says load SEF letter
Check if the orientation of the printing document matches to the paper available in the copier's trays.
Load SEF letter: means Load Short Edge Feed letter (landscape).
Good luck and please rate me, thanks.
Jan 30, 2009 | Ricoh 4506 Copier
Msg 'unable to start print job, is printer available'
A customer called me with the same msg. Let me explain first what the problem was..they had a Graphic PDF that on the HD was 20 MB but when extracted was well over 200 MB..first I had thought the pdf was exeeding the Printers memory but after testing it was not. The customer was printing the document using adobe PRO I had him print the document in reader 8.1 and made sure the print as image under advanced was selected and the document printed..
Aug 09, 2008 | HP PSC 1410v All-in-One Printer
Offending command: get
Offending Command: get. Graphics format in pdf document is not handled:
If you are the creator/owner of pdf document then edit pdf document and check Imported graphics.
If not try updating acrobat reader to last version.
If none of the above works, then only solution is to print document from different computer/printer.
regards
Mar 12, 2008 | Xerox Phaser 8560DN Laser Printer
Adobe Acrobat Professional 7.0
Try printing then scanning the PDF.
(Or spend the money to install Adobe Acrobat -- and I do not mean just the READER program)
I have no clue about your "error message displayed is saying that the documents contain renderable files."
Oct 23, 2007 | Adobe Acrobat Professional 7.0 for PC
HP LaserJet 4 plus Printer Logo
380 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
