HP Pavilion a1610n PC Desktop Logo
Anonymous Posted on Jun 24, 2010
In normal mode PC hangs due to spies or viruses. Unable to start the system in safe mode or safe ode in networking mode always it restarts if tried with safe mode. www.kaspersky.com, www.grisoft.com, www.symantec.com, www.pctools.com etc antivirus websites are not opening and unable to download any above trial version AV. While running msconfig, regedit nothing coming. gpedit.msc unable to activate msconfig or regedit. Please help how to remove the viruses downloading trial versions and so that PC runs in safe mode.
ONE-Touch-Solution
Level 3:
  • HP Master 1,679 Answers
  • Posted on Jun 24, 2010
ONE-Touch-Solution
HP Master
Level 3:
Answers
1679
Questions
Helped
404695
Points
5442
When you are restarting the PC - Press F8 Key till you get the options to Boot
Choose Last Known Good Configuration and load windows
Once you have logged into your PC - try to MSCONFIG
If that does not work, Open Task Manager ( CTRL + ALT + DEL ) key and Click on Services Tab. Click the Services Button below. and it should let you open SERVICES.MSC
Disable all the Antivirus software installed ( double click on the software name and under Startup type - choose Disable )
Also Disable the Windows Installer
Try to access or Download some Virus program to Run or Clean.
I can no longer use my laptop cause it will always hang eventhough i just newly open it.
Check the laptop if is heating up..if so then you can check for some kind of dust inside which is heating up the processor.
Do a virus check by going into safe mode with networking ,to go there restart the computer and then start tapping F8 on the keyboard in advance boot menu goto safe mode with networking and hit enter, there might be a virus in the computer..run a scan with malware bytes or hitman pro....google the two tools you will find the links..they are free.
5answers
Unable 2 remove viruses and unable to uninstalling AVG Anti virus.
There is an AVG removal tool here.
I would suggest MalwareBytes to remove viruses.
My laptop starts properly with the normal starting procedures when when started (with windows vista home premium 1) The mouse gets hanged and keep circling 2) The internet display that is network when...
Good Moring,
I have seen this behaviour in computers with virus (maleware) you can try the following
1)start your antivirus while log in safe mode and run a full scan
if virus is found remove it and start windows normally run a full scan afterwards
2) if no antivirus is install, i would recomend you to reinstall the OS
6helpful
3answers
How to remove classified.exe
Here's a step by step video instruction to get rid of Classified.exe:
Whenever I turn on my laptop it goes to the screen that says safe mode, safe mode with networking etc... then when i click say start windows normaly it has blue screen that stays for 2 secs and then the...
Select safe mode !
If it finishes booting into safe mode then you can try another re-start.
If on the other hand it does not work after being in safe mode the issue may lie in some software you have recently installed or new hardware.
in either case remove that hardware or software (in safe mode) and try again.
If it still insists on re-booting when you select normal then I would begin looking at possible mal-ware, spy-ware or virus issues.
Should you get a specific error message then that may also be useful in troubleshooting issues.
If this information was useful please click
I am unable to start up my computer at all... I can't get to my desktop to even try to fix the problem... what do i do? The message says: We apologize for the inconvience, but windows did not start...
You must have come in contact with a virus. Does your friend have the capability of slaving your hard drive to his to remove your data. If so, then he or you can reinstale the operating system.
Cannot start up laptop; may be a virus
Try starting your computer in safe mode and do a virus scan once in safe mode. While in safe mode Windows only loads the basic devices to run your computer and usually viruses are not loaded untill windows starts in regular mode. Don't panic once you are in safe mode and your screen looks all grainy, this is normal.
  1. Restart your computer and press F8 as soon as you turn it on.
  2. Click the "safe mode with networking" option
  3. Update your antivirus
  4. Do a full system scan
  5. Restart your computer and hope for the best.
Webroot spy ware
You will need to uninstall and install your program
Restart your computer--> black screen--> after the Bios check (is always the 1st step)--> start pressing the F8 key repeatedly--> Windows boot menu will apear--> use the arrows--> Safe mode
It will look different from you normal Windows (don't worry about this)--> go to Add / remove programs--> Uninstall your spysweeper program--> restart your computer normally--> install your program normally--> check for updates
2answers
Computer will not start
Choose Last Known Good Configuration. If that doesn't work, choose Safe Mode and then do a system restore to roll back your PC.
Any further questions, please use the comment box below to respond. Thanks.
Worldvet
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
