Question about KitchenAid Dryers
I have a kitchenaid electric dryer. The model
I have a kitchenaid electric dryer. The model no.: keye76owwh1. The heat does not
work. It is always no heat.
Thanks
    New Friend:
  • 30 Answers
Check thermostat first (it have about 5-8 of them inside) check on continues. if this all of them fine, the you have to check heater on continues too.
also if this is electric dryer check if you have 240v in power outlet.
all of this involve some kind of experience with electricity do you should be careful or ask professionals www.appliancesrepairla.com
Posted on Jun 26, 2010
Kitchenaid gas dryer won't ignite and heat. Everything else seems to work fine -- drum rotates, timer works, just no heat. Model# KGYL517BWH1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | KitchenAid Dryers
Replaced hi limit thermostat, thermal cutoff and heater, still not getting any heat. motor runs ok. model keys977e elec dryer.
heatman101
Aug 20, 2011 | KitchenAid Dryers
Kitchenaid Superba whisper quiet gas dryer Model # ykgys777eq1 will not heat could be igniter, glow rod or coil help?
heatman101
Jul 31, 2011 | Dryers
Kitchenaid gas dryer model # kgye800swh1 starts, but does not heatup
heatman101
Jul 04, 2011 | KitchenAid Dryers
The drum turns and the dyer blows air. It does not light, when I took it apart the ignitor does not come on. We replaced our gas coils about a year ago. what do you think might be causing the...
heatman101
Apr 26, 2011 | KitchenAid KGYS850LT Gas Dryer
I have a kitchenaid dryer that worked fine all day and then my last load to be dryed no heat not at all
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | KitchenAid KGYS750LQ Gas Dryer
Dryer is always "Cooling", doesn't heat. Why? How ...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | LG DLE2514 Electric Dryer
Dryer continues to heat when door is open
The model number you put up is for a gas dryer, but you said element, so I'm assuming it is actually electric.
If this is in fact an electric dryer, you most likely have a heating element that has shorted to the case. There is a small chance that something else in that circuit has shorted to ground but I doubt it.
If this actually is a gas dryer, please discontinue use immediately and get a licensed tech over there to look at it.
Good Luck
May 16, 2010 | KitchenAid KGYS850LT Gas Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryers Logo
170 people viewed this question
Top KitchenAid Dryers Experts
Marvin
Marvin
Ekse
durantheman
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
