You can create a Windows password reset disk to reset your password. Follow this 5 easy steps:
1. Enter a computer that can link to Internet. Google "windows password recovery tool 3.0". Download and install the software on that computer.
2. Run the software and create windows password recovery disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to recover admin password.
5. Now login Windows and set a new password.
Lost windows administrator password?Windows password key 8.0 has a neat trick that will get you back in.This method is easy for everyone to follow.
Download the utility from windows password reset website and install it then burn the software to a CD/USB drive,then insert the newly created CD/USB drive to your locked pc and reboot your computer,then press "F2" to enter your BIOS setup,following the instruction to reset your lost windows password.
I just want to say that WIndows password is not safe, some tools can remove it easily such as Windows Password Rescuer.
But you can just use it to recover your lost/forgot password. Don't use it to hack other's computer password!
You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows without login. With this New user account you can logon your locked computer directly.
If your system is Windows 7/vista/xp,you can use "Windows Password Rescuer Personal/Professional'.
If your system is Windows 2008/2003/2000,you can choose "Windows Password Rescuer Advanced".
You can create a Windows password reset disk to reset your lost or forgotten Windows password, i have created one with the tool Windows Password Breaker and reset my administrator password successfully.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
If you have lost windows login password,i think the best way for you is using a third party tool it won't cost you so much.And many people tend to use windiws password key,with this tool you can easily remove your lost windows password. Usually,when one realize they have lost their password,they like to reintall the system,it is not the best way.You can try to login to sate mode.On start up (before Windows loads) keep tapping either F5 or F8 (be aware that some manufacturers use F8 for system recovery!) then use arrow keys to highlight 'Safe Mode' and hit Enter/Return, click on a user account, enter the Administrator password (if you don't know it, there probably isn't one so leave it blank) and hit Enter/Return.I think this won't works for you as you have lost login password not user password. So the best way is using windows password key which is considered as the best tool to reset local administrator and user passwords on any Windows system. I have find this tool from http://www.recipester.org/Software:Windo...
If you
third party tool
password.
Windows loads) keep
recovery!) then use
enter the
leave it blank)
best tool to
