Displays;Turn power off and on again.Tried to reset,still the same.
This problem occurs due to following reason. 1) Your battery has become inefficient... In this case change your battery.. that means replace old battery with new one.
2) Motor which manages lens has been malfunctioning... In this case you have to get it serviced...
3) Firmware of the cam has been corrupted. In this case also you have to get it serviced..(This option is very rare)
Hope this has helped you... Please rate the answer.. Thanks...
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Yogesh, all three reasons that you mentioned are wrong/ incorrect for Sony camera. You do not know how Sony camera works.
