Power Acoustik LT-980/2 Car Audio Amplifier Logo
joe rosa Posted on Jun 24, 2010
How many watt thus a Power Acoustik LT-980/2 do?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
531
Points
Normally check the fuse (s) example if the fuse is 40 amps the amp can do 430 rms...
1helpful
2answers
How do i fix my Power Acoustik LT-980/2 car amp, it keeps on going into protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
How do i find how many ohms my amp is because i cant find it here the name of my amp is poweracustick lt 980-2 of 980 watt i want to know that so i know what speaker to hook up with
According to a listing on epinions, it appears that the amp is 8 ohms per channel standard, and can be bridged to 4ohms.
One post says that he has it bridged to 4 ohms and is getting 560 watts of output.
I couldn't find a manual for it, so you may want to contact Power Acoustik to be sure.
1helpful
I would like to know how watts or rms is it
220 Watts X 2 @ 4 Ohm RMS
• 280 Watts X 2 @ 2 Ohm RMS
• 980 Watts X 1 Bridged Output
• 560 Watts X @ Mono RMS
1helpful
LT-980/2 Car Audio Amplifier: Looking to see if I can hardwire a Power Acoustik ...
you want to use a car amplfier indoors in the house
yeah that can be done very easily
just wire it like you would inside a car but you need to purchase a 12v DC adapter
i would go for one with at least 3A output (the bigger the better it depends on how much u wanna spend) from personal expericance 1.5A works but when it gets loud the amp stops and restarts
Power Acoustik LT 980-2 clipping while bridged pushing 1ohm load
Hello, your problem is that your amp is rated at 4 ohms bridged mono ans 2 ohms stereo. If your running it in stereo you need to raise the ohms to 2 ohms a channel and if your running it bridged into 1 channel you need to be running it at 4 ohms. Please rate this solution please so I can prgress on FixYa.com. Thanks!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Lt960-4 power acoustik Amp 4 channels mono
it can be used as a bass amp. if each pair of channels is bridged then you will basically have a 2 channel amp. just be sure to set the x-over's to lpf for subwoofers. I checked the power ratings, and bridged at a 4 ohm load will give you 250 rms watts per sub, so thats enough to run most 10's or 12's. there wasnt a rating for a 2 ohm load, but your amp should support it.
1helpful
2answers
WIRING
You need to order extra components in order to use the optional GPS function.. you can try checking circuit city or the Authorized Acoustik Suppliers for the products like the websites or you can check Ebay as someone might have the product
HELP
Disconnect all of the speaker wires and signal cables from the amplifier.
If the amp still goes into protect when you power it up, the output transistors are likely shorted.
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
