SOURCE: deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
In your windows media you will see the device name listed..you have to make sure the device is under MTP mode..then click on the player and you will see all the songs...you can just right click on the songs and delete them..if you dont want the device to sync automatically you can click on sync and then click on the device name and click on sync setting..there you can modify if you want it to sync automatically..
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
SOURCE: how do you delete songs off of a sandisk sansa m240 music player
In My computer right click on the mp3 player and select format..then it will delete all songs..
SOURCE: deleting songs
In the player go to Settings->USB and set MSC. Now connect it to your computer and you'll be able to find the songs in the removable drive.
SOURCE: There are songs on my San Disk Sansa M240 MP3
ok
See if that your folder options is not set to (do not show hidden files and folders .
Follow these steps to check it:
1. open control pannel.
2.Double click folder options then click view
3. then scroll and locate Hidden files and folders.
4.select show hidden files and folders.
5.Also untick the hide extension for known files type:
ok
cheers
uttam
well go to my computer(with the usb in) and clik on ur snasa mp3 player thing
then go to recordings and delete watever u dont need but how do i delete music i cant see???? AAAHAHHAHAHKKKK!!!! :(
