SanDisk Sansa E280 MP3 Player Logo
A
Anonymous Posted on Jun 24, 2010
I want to delete all my music. How can I do ?
2answers
Delete songs from i pod touch 2nd generation
You must connect to the computer with iTunes. There you can select the music you want t delete.
For that wait till the iPod is backed up by iTunes, then on the left side click on the line with the name of your iPod. Then on top click on Music and then you see what music you can synchronise.
If you already did remove the original backups from the music on the iPad, there is a chance iTunes all remove all these numbers.
Apple has lots of info about every part you want to know about your iPod and iTunes.
2answers
How to delete music off your ipod
Hi David,
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer.
The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod.
How to Delete Music from iPod in Batch
2answers
How do I delete songs from my ipod?
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer. The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod. Open up iTunes by double clicking on the "iTunes" icon. Go to "Library" on the far left side of the screen. Click "Music" from this list, which will bring up all your music on the main part of the screen. Choose a song you would like to delete from the list and right click on it. Click "Delete" from the drop-down menu that appears to delete your song. Go to the bottom of the left column on the screen to "Playlists." Click on one of your playlists to bring up the list of songs in the list. From there you can delete a song on the list. Connect your iPod to your computer. The iTunes program will automatically sync your iPod to whatever you have changed in your iTunes library as long as it is set to the default settings. Manually Delete Music Connect your iPod to your computer. Open up iTunes. Choose the third option in the "Options" menu called "Manually manage music" by checking the box next to it. It will ask you if you are sure you want to manually manage music on your iPod. Click "OK." Go to "Devices" on the far left column on your screen. You will see your iPod's name directly underneath that with an arrow pointing to the right. Click on the arrow, which will cause it to rotate until it is pointing downward and a drop-down menu will appear with all your songs listed. Click on a category or playlist, which will bring up all the songs in the list in the main section of the screen. Choose on a song listed that you would like to delete and right click on it, then click "Delete" from the drop-down menu that appears to delete your song.
2answers
I DON'T KNOW HOW TO DELETE MUSIC ON MY IPHONE 3G
iTunes.
Go to your iTunes library of music. UNCHECK the songs you don't want from that list. Then resync the phone and it'll remove all that you unchecked from the phone...
Confusing and over complicated, yes. But the list on iTunes is the list in the phone. So what ever you check or uncheck is whats on or off the phone
5answers
How do i delete songs from an Iphone 3gs
1.Go to Settings
2. Go to General
3. Go to Usage
4. Wait for Storage to load
5. Go to Music and swipe
6. Delete will pop up
7. Press Delete
This will delete ALL songs, but will not remove the music app.
There you go.
How to Delete Songs from iPhone
iPhone Data Eraser Clean up Data Safeguard for Ultimate Privacy...
2helpful
2answers
How do you delete songs from Ipod?
To delete music connect ipod to itunes on computer.In music folder under your ipod name you can then delete music.
3answers
Deleting songs , how do you delete songs off the ipod touch?
connect it to itunes.. click on the ipod and under the music tab.. uncheck sync all music from music library
2answers
How do I delete music from my ipod
to delete music from your ipod you must delete it from itunes
connect the usb cord that connects your ipod and computer. open your itunes go to your music files right click to the song(s) you want to delete once you completed this steps SYNC your ipod. uplug your ipod this should help
Deleting downloaded,saved music
Next time it's plugged in, follow this.(on windows)
Go to My computer>WALKMAN(next to control panel) Music, All music, then right clikc on things you want deleted and press delete.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
